36 minutes ago, PrinzII said:
Another thing I'm looking to do is the 75k Maintenance plus the Transmission flush on my 2018.  I need to get that done before the heat in AZ hits.
I am at 70k right now on my 2021. Soon I will replace the transmission fluid, oil change, and maybe RDU? and PTU?
Things to consider as well:
Power steering
Brake fluid
PTU
Coolant
Blinker
RDU (90k or after anytime car driven through deep water)
Can of fuel injection & system cleaner (1-2× year)
Cabin filter
Check air pressure in spare tire
  • Thanks 1
Those are all good things to consider. I will also have to replace the battery soon. I have a battery jump starter with me, so right now I am just waiting until the battery gets low enough to not start the car anymore. Is there maintenance for power steering because it is electric? Ford says to change the brake fluid every 3 years now. I should get that done when I replace / upgrade my ABS module soon. What do you mean by "blinker"? Turn signal bulbs? I recently changed the cabin air filter. I got the filter on clearance sale from Walmart.
