Wubster100 Posted July 12, 2024 Report Share Posted July 12, 2024 On 6/16/2024 at 8:06 PM, sc00by said: Yesterday I disabled the fake engine sounds and seat belt minders using forscan. Today I washed the car. Expand Does the Edge have a fake engine noise? Or did you disable the noise canceling? Quote Link to comment Share on other sites More sharing options...
sc00by Posted July 12, 2024 Report Share Posted July 12, 2024 On 7/12/2024 at 3:51 PM, Wubster100 said: Does the Edge have a fake engine noise? Or did you disable the noise canceling? Expand Disabling the ANC disables fake engine sounds per forscan posts. I also needed to disable ANC to accommodate an aftermarket sub. 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 13, 2024 Report Share Posted July 13, 2024 Just a FYI, one other item you might take into account when installing aftermarket speakers, is interference with the AnvanceTrac stability control systems. Some guys are not aware of this potential problem. For your reference: In addition, installing any stereo loudspeakers may interfere with and adversely affect the AdvanceTrac with RSC system. Install any aftermarket stereo loudspeaker as far as possible from the front center console, the tunnel, and the front seats in order to minimize the risk of interfering with the AdvanceTrac with RSC sensors. Reducing the effectiveness of the AdvanceTrac with RSC system could lead to an increased risk of loss of vehicle control, vehicle rollover, personal injury and death. 2 Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted July 14, 2024 Report Share Posted July 14, 2024 (edited) Oil and filter change after 4345 mi. with 57% remaining on OLM, blow out air filter, check fluid levels. 5 quarts and 14 ounces fills to the top of the cross hatching and 16 ounces puts it an acceptable amount above. Edited July 14, 2024 by Tim W. AZ 2 Quote Link to comment Share on other sites More sharing options...
sc00by Posted July 14, 2024 Report Share Posted July 14, 2024 Attempted to install a CVF intercooler. Attempted. They didn't put threads on the end tank for the map sensor...😮 1 1 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 15, 2024 Report Share Posted July 15, 2024 On 7/14/2024 at 1:21 PM, Tim W. AZ said: Oil and filter change after 4345 mi. with 57% remaining on OLM, blow out air filter, check fluid levels. 5 quarts and 14 ounces fills to the top of the cross hatching and 16 ounces puts it an acceptable amount above. Expand I would question adding oil above the max mark. On a 2.0 L, (think you have the 2.0 L) the manual calls for 5.7 quarts. You put in nearly 6 quarts (and that doesn't count what dirty oil was still left in the engine.) Adding too much allows the crankshaft to contact the top of the oil level, causing splashing and foaming. As the oil pickup floats on top of the oil, it draws the foam into the engine, starving the engine for lubrication it's the top components, the cams and associated parts, that suffer first. Also not a fan of blowing out a dirty air filter. Blowing out a dirty car air filter only removes loose surface debris and will probably damage the filter fibers, making the filter less efficient. It will also leave behind deeply embedded particals. Compressed air will forces dirt deeper into the filters leaving the filter partially clogged. New filters are cheap insurance. 3 Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted July 15, 2024 Report Share Posted July 15, 2024 On 7/15/2024 at 11:05 PM, enigma-2 said: I would question adding oil above the max mark. On a 2.0 L, (think you have the 2.0 L) the manual calls for 5.7 quarts. You put in nearly 6 quarts (and that doesn't count what dirty oil was still left in the engine.) Adding too much allows the crankshaft to contact the top of the oil level, causing splashing and foaming. As the oil pickup floats on top of the oil, it draws the foam into the engine, starving the engine for lubrication it's the top components, the cams and associated parts, that suffer first. Also not a fan of blowing out a dirty air filter. Blowing out a dirty car air filter only removes loose surface debris and will probably damage the filter fibers, making the filter less efficient. It will also leave behind deeply embedded particals. Compressed air will forces dirt deeper into the filters leaving the filter partially clogged. New filters are cheap insurance. Expand The 2020 manual specifies 5.5 qts., or 5 qts and 16 ounces, and that takes it slightly above the crosshatching, but well below the max fill level. As I posted earlier, 5 qts and 14 ounces takes it to the top of the crosshatching. The air filter has only 4 months and 4500 miles on it, so it was pretty clean to start with. I don't blow through the filter, I carefully separate the ribs and blow sideways, so I'm not too worried about blowing out the filter and the air box was clean of fine particles. I'm pretty comfortable with my process. 2 Quote Link to comment Share on other sites More sharing options...
Edge_u_Cational Posted July 20, 2024 Report Share Posted July 20, 2024 On 6/18/2024 at 7:22 PM, PrinzII said: Still doing dashcam research for both my SEL and wifey's Escape. Expand Dongar Technologies makes a nice adapter. loops through the rearview mirror power. though if you want parking monitoring you'll want to find a constant 12v signal Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 21, 2024 Report Share Posted July 21, 2024 changed all driveline fluids eng oil change, trans fluid change, PTU drain & refill, RDU evacuate and top with smurf snot (Redline LW Shockproof) 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 22, 2024 Report Share Posted July 22, 2024 Thought smurf snot was gen x slang for the color your snot turns (blue) after snorting adderall. Tish, tish Cerberus .... 😊 1 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 22, 2024 Report Share Posted July 22, 2024 On 7/22/2024 at 4:24 AM, enigma-2 said: Thought smurf snot was gen x slang for the color your snot turns (blue) after snorting adderall. Tish, tish Cerberus .... 😊 Expand I wouldn't know, I've never tried it, nor heard the term before in that context. I grew up before that was a thing, before big pharm muscled into the recreational market. 1 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 22, 2024 Report Share Posted July 22, 2024 On 7/21/2024 at 6:28 PM, Cerberus said: changed all driveline fluids eng oil change, trans fluid change, PTU drain & refill, RDU evacuate and top with smurf snot (Redline LW Shockproof) Expand What I didn't mention is that the RDU fill plug magnet was pretty furry again, and I've been hearing dry bearing / hypoid whine noise from the rear section of the driveline so I need to either get ready to do the rear end swap (already have one to install) or trade the vehicle (the easier but less desirable option, because I do like this vehicle) I just wish I had a lift to do the job on. 3 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted July 24, 2024 Report Share Posted July 24, 2024 Did fluids on the my 2019 ST. The oil change is no big deal. PTU is a pain. I drained the unit by removing the cooler bolts and just sliding the cooler out enough to let the fluid drain. Those bolts are not easy to get at. I think the two bolts alone, took over an hour to remove and replace. I filled it using one of those 500ml syringe things you see on Amazon. The differential is easy except getting the input plug out. It is a 3/8 square female plug. Should be easy, but Ford puts a cross brace in the way. I ended up partially rounding the end of an extension to make it a square ball. I used Ford fluids for the PTU and Differential. $79 for both at the dealer. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 25, 2024 Report Share Posted July 25, 2024 My Lincoln dealer uses the RDU vacuum equipment to suck out the PTU fluid and pump new fluid in. Something like this might mat the job easier next time (I havent actually used this, I'd rather pay the dealer to do it.) Thorstone Automotive Fluid Extractor Pump with long rubber hose, Oil Change Syringe with Hose, Manual Fuel Suction & Filler, Fluid Oil Change Evacuator (7 Oz./0.21 Qt./200 CC) https://a.co/d/4f4gFIf Quote Link to comment Share on other sites More sharing options...
TourGuide Posted July 27, 2024 Report Share Posted July 27, 2024 I emptied my JL oil can yesterday after ~1500 miles and found it had about .25 to .5 ounce of oil in it. I'm glad it is working and that I saved that from going into the intake but I am also pretty sure I can safely empty it every time the oil is changed. Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 28, 2024 Report Share Posted July 28, 2024 On 7/22/2024 at 6:24 AM, Cerberus said: What I didn't mention is that the RDU fill plug magnet was pretty furry again, and I've been hearing dry bearing / hypoid whine noise from the rear section of the driveline so I need to either get ready to do the rear end swap (already have one to install) or trade the vehicle (the easier but less desirable option, because I do like this vehicle) I just wish I had a lift to do the job on. Expand so i unplugged the electrical connector to the RDU and suddenly its silent. I'll take that as a temporary win Went for a ride for ~20 miles and noticed the PTU temperature is absolutely not any cooler than before, maintaining about a 10 degree bump above te transmission fluid temperature, which suggests that (as I suspected) the majority of the heat load that the PTU deals with is radiant from the rear catalyst, not from frictional heat. also, the 170 thermostat keeps the engine coolant (and also the average head temperature) around 15 degrees cooler without any special tune modification. Granted i was not in gridlock, but i was doing some stop and go traffic after the highway run. 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 31, 2024 Report Share Posted July 31, 2024 Great deal on a 3 pack of LV Fluid. With tax, comes out to ~$18 per jug for me from Amazon: https://a.co/d/1wADj8f 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 31, 2024 Report Share Posted July 31, 2024 On 7/31/2024 at 1:33 AM, lildisco said: Great deal on a 3 pack of LV Fluid. With tax, comes out to ~$18 per jug for me from Amazon: https://a.co/d/1wADj8f Expand I've contemplated using this but have just erred on the side of caution and went with Motorcraft, but if I see enough good reports of owners here using it, I might go with it for the next trans fluid drain and fill which will be in a couple of years from now. That special has passed, but I've seen it reappear a few times recently. Valvoline Multi-Vehicle (ATF) Full Synthetic Automatic Transmission Fluid 1 GA, Case of 3 $51.00 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 31, 2024 Report Share Posted July 31, 2024 Booo that stinks. It pops up from time to time. I believe that MacT has reviewed it, but I'm not sure if he's done an analyst of the fluid or not. Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 31, 2024 Report Share Posted July 31, 2024 On 7/31/2024 at 12:10 PM, 1004ron said: I've contemplated using this but have just erred on the side of caution and went with Motorcraft, but if I see enough good reports of owners here using it, I might go with it for the next trans fluid drain and fill which will be in a couple of years from now. That special has passed, but I've seen it reappear a few times recently. Valvoline Multi-Vehicle (ATF) Full Synthetic Automatic Transmission Fluid 1 GA, Case of 3 $51.00 Expand Kendall Versatrans LV is specifically licensed to be in compliance with the spec my Trans requires. For whatever that is worth.. I buy it by the case of quarts, do not recall the price 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted July 31, 2024 Report Share Posted July 31, 2024 If Valvoline won't pay for licensing or get it tested to see that it meets Mercon LV specs, I pass. 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 31, 2024 Report Share Posted July 31, 2024 It says Mercon V/LV on the jugs, but are you saying that they didn't actually do the testing to say that? Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 31, 2024 Report Share Posted July 31, 2024 On 7/31/2024 at 9:59 PM, lildisco said: It says Mercon V/LV on the jugs, but are you saying that they didn't actually do the testing to say that? Expand Mercon V & Mercon LV are entirely different specs.. or else Ford would not have created the different name.. (unless possibly just as a money grab?) So a fluid that sites both specs is automatically suspect in my book. 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 31, 2024 Report Share Posted July 31, 2024 Oh I agree that they're different specs, but I've seen other companies do the same thing Quote Link to comment Share on other sites More sharing options...
dabangsta Posted July 31, 2024 Report Share Posted July 31, 2024 On 7/31/2024 at 9:59 PM, lildisco said: It says Mercon V/LV on the jugs, but are you saying that they didn't actually do the testing to say that? Expand Their product information sheet states it is not an OEM licensed product, and that no vehicle manufacturer has tested, evaluated, or endorses the product. https://sharena21.springcm.com/Public/Document/18452/9e447451-fe75-e711-9c10-ac162d889bd3/5ca3517a-e29c-e711-9c10-ac162d889bd3 They do not have an OEM licensed product for Mercon LV (or ULV) but do for Mercon V. Plenty of companies license it, but rarely is it included with a broad "one fluid for all" cover all specs fluid. 1 Quote Link to comment Share on other sites More sharing options...
