Cerberus Posted February 8, 2023 Report Share Posted February 8, 2023 On 2/8/2023 at 1:26 PM, dabangsta said: Seems more like condensation than a full on water/coolant leak into the crank case. Do you live in a humid climate, do lots of cold starts, and possible not get it up to temp and keep it up to temp for your drives? I would get water emulsion on the oil fill cap on a few of my cars in the colder but not frozen parts of the year. Expand Filler cap has no milky crap on it. Fairly humid and not too stupid cold here, but it almost always gets up to temp once started 1 Quote Link to comment Share on other sites More sharing options...
bofus Posted February 15, 2023 Report Share Posted February 15, 2023 Added molded mudflaps to my 2018 Ford Edge Sport. Bought these: https://www.amazon.com/dp/B083L9NS9D There was no documentation that came with my set. The rears fit perfectly and I felt good about the way they mounted. I did not like the way the fronts were to be mounted and so I got some additional hardware. For the 3 bolts inside the fender lining, I used these instead of their tiny screws. The little j-nuts that came with the mudflaps were too small to use. I did crimp these larger j-nuts down so they can't really move once you slide them onto the bottom rocker molding piece. https://www.amazon.com/dp/B079C4M34G For the single hole underneath, it wasn't going to hold to just re-use the push-in fastener and it's too short anyhow with the added thickness of the mudflap. I drilled out the hole slightly in the body and installed a rivnut and used a threaded bolt to hold the mudflap and the bottom rocker molding in place. The mudflaps up front are NOT going anywhere now. No cutting of any fender lining or anything required. Only modification was enlarging the hold in the body slightly for a rivnut insert. Rivnut kit I used: (I think I used the M6 size for the bolt..I'd have to check) https://www.amazon.com/dp/B07MMBHSMX 1 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted February 17, 2023 Report Share Posted February 17, 2023 For you guys doing Forscan changes, do you have a spreadsheet somewhere on this site? I am a member on F150forum and we have an EXTENSIVE spreadsheet. Thanks 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 17, 2023 Report Share Posted February 17, 2023 On 2/17/2023 at 1:38 AM, Summers22 said: For you guys doing Forscan changes, do you have a spreadsheet somewhere on this site? I am a member on F150forum and we have an EXTENSIVE spreadsheet. Thanks Expand Give the search feature a try. Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 17, 2023 Report Share Posted February 17, 2023 On 2/5/2023 at 12:58 PM, Cerberus said: drained my catch can. nasty light oily garbage with some milky sludge in the bottom Expand That's what mine looks like and even more of it in the cold months. 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 17, 2023 Report Share Posted February 17, 2023 On 2/8/2023 at 9:26 AM, enigma-2 said: That's not good sign. You losing cooant? Expand Actually a good sign that the catch can is working well. 1 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted February 17, 2023 Report Share Posted February 17, 2023 On 2/17/2023 at 1:41 AM, 1004ron said: Give the search feature a try. Expand So thats a no, thanks. Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 17, 2023 Report Share Posted February 17, 2023 (edited) On 2/17/2023 at 1:38 AM, Summers22 said: For you guys doing Forscan changes, do you have a spreadsheet somewhere on this site? I am a member on F150forum and we have an EXTENSIVE spreadsheet. Thanks Expand There is no extensive sheet for the Edge, only some personal (small) sheets and mods all over this thread (edit: and this thread). However, the 2015-2020 F-150, 2016-2019 Explorer and 2013+ Fusion sheets are mostly applicable to 2015+ Edges. Though I am not sure for newer Edges with Sync4A if it is still applies or not. Edited February 17, 2023 by omar302 3 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted February 17, 2023 Report Share Posted February 17, 2023 Thank you, much appreciated! Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 19, 2023 Report Share Posted February 19, 2023 (edited) On 2/8/2023 at 9:26 AM, enigma-2 said: That's not good sign. You losing cooant? Expand Perfectly normal. Just drained ours in our 2016 2.0L Given enough time, you'll see the oil, gunk, gas, water separate Edited February 19, 2023 by lildisco 2 Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted February 21, 2023 Report Share Posted February 21, 2023 Changed the oil. 142,000 miles with 132,000 of that on a unleashed tune. Still handling her daily duties well! 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 22, 2023 Report Share Posted February 22, 2023 On 2/17/2023 at 1:42 AM, 1004ron said: That's what mine looks like and even more of it in the cold months. Expand Starbucks chocolate carmal latte? Yummm. 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 24, 2023 Report Share Posted February 24, 2023 2020 SEL AWD PTU drain & fill tonight. Tomorrow an oil change before a road trip to Alabama next week. Fluid still had a brownish tint to it, 17,870 miles. I'll swap it again when I get closer to 30,000. 1 Quote Link to comment Share on other sites More sharing options...
Totally_Ripped Posted February 28, 2023 Report Share Posted February 28, 2023 (edited) Installed a 20" LED strip light in the grill of my wife's 2011 Ford Edge Limited. Edited February 28, 2023 by Totally_Ripped 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 28, 2023 Author Report Share Posted February 28, 2023 On 2/28/2023 at 1:49 AM, Totally_Ripped said: Installed a 20" LED strip light in the grill of my wife's 2011 Ford Edge Limited. Expand spot or flood? 1 Quote Link to comment Share on other sites More sharing options...
Totally_Ripped Posted March 1, 2023 Report Share Posted March 1, 2023 (edited) On 2/28/2023 at 8:58 AM, WWWPerfA_ZN0W said: spot or flood? Expand Only spot! Flood blinds people. Edited March 1, 2023 by Totally_Ripped 2 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted March 4, 2023 Report Share Posted March 4, 2023 92k miles Oil and filter Summer /winter wheel swap Rear pads and rotors (Raybestos Element 3) Drained the catch can again, had about a tablespoon of very dark, thin, oily crap. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 6, 2023 Author Report Share Posted March 6, 2023 (edited) doesnt look like any water was mixed in the catch can drain, which is good. did it smell like fuel? @Cerberus Edited March 6, 2023 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Cerberus Posted March 6, 2023 Report Share Posted March 6, 2023 On 3/6/2023 at 7:21 AM, WWWPerfA_ZN0W said: doesnt look like any water was mixed in the catch can drain, which is good. did it smell like fuel? @Cerberus Expand No, it smelled like old used oil. And I'm not being a wiseass, that is a definite smell. Hydrocarbon combustion, pressure leakage past the rings (which is unavoidable to some degree, especially in boosted applications) create a distinct smell. 1 Quote Link to comment Share on other sites More sharing options...
ulyssesmeads Posted March 25, 2023 Report Share Posted March 25, 2023 (edited) wash, wax, and tire shine! trynatim Edited November 1, 2023 by ulyssesmeads Quote Link to comment Share on other sites More sharing options...
TourGuide Posted March 26, 2023 Report Share Posted March 26, 2023 (edited) Recently had my 19 rustproofed and had the paint high speed buffed then waxed. Came out nice. In addition I had the RDU and P"TU serviced (PTU as much as could be sucked out then refilled). I used Red Line fluids for this. Also replaced the cabin air filter with a WIX mutilayer - the OE was pretty dirty. Going to handle the rattles from the rear lift gate when I have time to pull the body panels and give it the treatment. Edited March 26, 2023 by TourGuide 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted March 27, 2023 Report Share Posted March 27, 2023 (edited) Your 2019 PTU has a drain plug, why did you need to suck it out? Unless you mean that you drained it & then tried to suck out any fluid/chunks? To my knowledge Redline does not make an RDU fluid for your edge. It's a speciality 75W from Ford & the 75W-90 Redline fluids aren't compatible. https://www.fordedgeforum.com/topic/31446-2020-sel-awd-rdu-fluid-redline-lightweight-shockproof-work/?do=findComment&comment=230273 Edited March 27, 2023 by lildisco 1 Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted March 27, 2023 Report Share Posted March 27, 2023 (edited) If he has an ST model the PTU doesn't have a drain plug unfortunately. But definitely would stay with the Ford recommended fluids especially if your vehicle is still under warranty Edited March 27, 2023 by kruzr1 Quote Link to comment Share on other sites More sharing options...
TourGuide Posted March 27, 2023 Report Share Posted March 27, 2023 My 2019 ST has a PTU cooler and no drain plug - THANKS Ford! So the suck out and replace was as far as I felt like taking it expense wise for now. Red line does make compatible fluids for both of the applications. I used this for the RDU - and - this for the PTU Ester base stock (even if in name barely) I consider better options than OE. This unit is past warranty, but I do have an extended warranty to cover anything big. 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted March 28, 2023 Report Share Posted March 28, 2023 (edited) On 3/27/2023 at 8:07 PM, TourGuide said: My 2019 ST has a PTU cooler and no drain plug - THANKS Ford! So the suck out and replace was as far as I felt like taking it expense wise for now. Red line does make compatible fluids for both of the applications. I used this for the RDU - and - this for the PTU Ester base stock (even if in name barely) I consider better options than OE. This unit is past warranty, but I do have an extended warranty to cover anything big. Expand Not according to Omar & Motorcraft on the above link provided: Link to Motorcraft page for this oil. It also states "Do not use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended I'm not an engineer, but I'm assuming that you've done your research. I ended up using XY-75W-QL fluid from Ford. Hopefully in the next 20,000ish miles Redline will have (or has) something available to use that's MUCH cheaper than Ford's version & obviously better. Edited March 28, 2023 by lildisco 4 Quote Link to comment Share on other sites More sharing options...
