Fifth_Ford Posted October 13, 2007 Report Share Posted October 13, 2007 Does anybody know if there is a simple way to change the power state for the accessory plugs. I have a portable GPS permanently mounted but won't power down when the car turns off. This is because the accessory plugs remain on without the key. My father-in-law has a Ford 150 King Ranch and his plugs do power down when the ignition is turned off. Any ideas..... Quote Link to comment Share on other sites More sharing options...
ClubwagonXLT Posted October 13, 2007 Report Share Posted October 13, 2007 (edited) - Edited October 21, 2007 by ClubwagonXLT Quote Link to comment Share on other sites More sharing options...
rcrose Posted October 13, 2007 Report Share Posted October 13, 2007 Fifth_Ford said: Does anybody know if there is a simple way to change the power state for the accessory plugs. I have a portable GPS permanently mounted but won't power down when the car turns off. This is because the accessory plugs remain on without the key. My father-in-law has a Ford 150 King Ranch and his plugs do power down when the ignition is turned off. Any ideas..... There is probably a dedicated fuse position for the accessory receptacles and it would involve moving or jumpering the wiring to a fuse that is controlled by the ignition switch. Years ago I installed two-way radios in vehicles and the fuse blocks were divided up that way. With the level of sophistication found in modern rides, you might not want to make such a modification. Your dealership might take a dim view of that so I'd get their input. Be careful and good luck. Quote Link to comment Share on other sites More sharing options...
Fifth_Ford Posted October 13, 2007 Author Report Share Posted October 13, 2007 ClubwagonXLT said: Yes---pull the plug of the gps out of the socket. Thanks, I will take that into consideration Quote Link to comment Share on other sites More sharing options...
