2012 Edge SE heater not working
melgriffith
Per my 2007's shop manual, these are the diagnostic steps:
  • Low engine coolant level
  • Engine overheating
  • Plugged or partially plugged heater core
  • Temperature blend door is binding or stuck
  • Temperature blend door actuator
  • Heater hose is kinked or binding (check very carefully when engine is warmed up, may be hot enough to burn)
The actual controls (mechanical/electronic) are not mentioned, but there could be a fault in there as well.
  • 2 years later...
  • 10 months later...
  • 1 year later...
