DBEDGE23 Posted October 1, 2013 Report Share Posted October 1, 2013 Had the fuse blow on the positive side of the battery... I did search the forums but when I went out to Fordparts.com I can't find the part. Does anyone know where to get this part without having to buy the whole positive cable kit?? Please, any help would be appreciated!!!! Thanks, DBEDGE23 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 1, 2013 Report Share Posted October 1, 2013 (edited) Positive battery terminal: The negative terminal part number is BT4Z-14450-BA That won't help you here, but ... Found an actual thread on this forum: http://www.fordedgeforum.com/topic/10271-fuse-block-on-positive-battery-terminal/ Same problem, looks like. http://www.fordparts.com/Commerce/PartDetail.aspx?n=ckOj1GrDwo0yAK5tP%2bja2Q%3d%3d&id=250462919&m=2&search=true&year=2013&make=Ford&model=Edge http://www.fordparts.com/Commerce/PartDetail.aspx?n=4jZhJdOXoukTSzh86m5dDw%3d%3d&id=252068156&m=2&search=true&year=2013&make=Ford&model=Edge Edited October 1, 2013 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
DBEDGE23 Posted October 1, 2013 Author Report Share Posted October 1, 2013 Thanks!!! I think this is it! DBGOLF23 Quote Link to comment Share on other sites More sharing options...
DBEDGE23 Posted October 3, 2013 Author Report Share Posted October 3, 2013 So after replacing the fuse block - everything seems to be working fine. However I have three dash lights that are on - BRAKES - ABS - Traction Control - Is there some sort of reset I need to do? Quote Link to comment Share on other sites More sharing options...
akirby Posted October 3, 2013 Report Share Posted October 3, 2013 So after replacing the fuse block - everything seems to be working fine. However I have three dash lights that are on - BRAKES - ABS - Traction Control - Is there some sort of reset I need to do? You probably blew a fuse messing with the batter cables. Check all the fuses inside and under the hood. Quote Link to comment Share on other sites More sharing options...
DBEDGE23 Posted October 3, 2013 Author Report Share Posted October 3, 2013 I found the issue. When installing DaytimeBrightlights DRL I put the fuse back in slot 91 instead of 92. Everything is fine now. Thanks! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 3, 2013 Report Share Posted October 3, 2013 keep on rockin' Quote Link to comment Share on other sites More sharing options...
born2gogolf Posted October 8, 2013 Report Share Posted October 8, 2013 The part number for the battery terminal circuit/fuse is #AE5Z14526A Quote Link to comment Share on other sites More sharing options...
