Cougarpaw99 Posted September 27, 2013 Report Share Posted September 27, 2013 Hello everyone! I've had my Edge for a while now, and this is the first time I changed the oil myself. I couldn't believe how easy it was. The hardest part was cleaning the oil I spilled on my driveway. So...for anyone who is thinking about doing it themselves, I say "go for it". After buying the filter and oil, I saved about $20 from taking it to the dealership and it only took me about 20 minutes. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 27, 2013 Report Share Posted September 27, 2013 Did you have to put the Edge up on ramps/jacks at all? I find there is just enough room to get by without. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted September 28, 2013 Report Share Posted September 28, 2013 I've down my own maintenance on all of my cars for the last 45 years. I do it because I know how to do it, I enjoy doing it, and I can inspect other things while I'm doing it. I also know that it is done correctly and no short cuts were taken. With that said, there have been a few times in the last several years I have taken advantage of the Ford Works package at the local dealer. For $29.95 plus tax (after a $10.00 rebate) I get 5 quarts of FMC synthetic blend 5W20 oil, a FL500S oil filter, and tire rotation. I also get a multi-point inspection including brake condition and thickness, battery charge and condition, etc. Sure beats doing that in my garage using some floor jacks when the temperature is over 100 degrees. I've also had it done when I've been working out of state and the 5000 mile interval came due. I'm really not saving that much money when I do it myself, so I don't mind when I do have to have a dealership do it, as long as they have the $29.95 after rebate Works Package deal. 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted September 28, 2013 Report Share Posted September 28, 2013 I agree, Edges are super easy. I just take the front drivers side up a little with a floor jack to make it easier to slide under the front. Never trusted the dealership or any of the quick change places to do a simple oil change. Thanks to a fellow member, I got in on that $5.00 five qt jug deal and have enough Motorcraft 5w20 to last me to 150,000 miles. Quote Link to comment Share on other sites More sharing options...
Cougarpaw99 Posted October 2, 2013 Author Report Share Posted October 2, 2013 On 9/27/2013 at 7:46 PM, WWWPerfA_ZN0W said: Did you have to put the Edge up on ramps/jacks at all? I find there is just enough room to get by without. I didn't have to use any jacks or ramps. I'm a pretty tall guy (6'3", 200lbs) and I could reach everything fine. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 2, 2013 Report Share Posted October 2, 2013 I don't have to use ramps either. Wish the Focus and Fusion were that easy. Not only do you need ramps but you have to remove a large cover with 7 or 8 torx screws each time. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 2, 2013 Report Share Posted October 2, 2013 Is that the bellypan you are referring to? On the SHO, they say they added for aerodynamics and cooling (translates into MPG), so probably the same there. Still a PITA. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 3, 2013 Report Share Posted October 3, 2013 Yep and yep. Quote Link to comment Share on other sites More sharing options...
EDST777 Posted January 7, 2015 Report Share Posted January 7, 2015 On 9/28/2013 at 12:13 AM, ls973800 said: With that said, there have been a few times in the last several years I have taken advantage of the Ford Works package at the local dealer. For $29.95 plus tax (after a $10.00 rebate) I get 5 quarts of FMC synthetic blend 5W20 oil, a FL500S oil filter, and tire rotation. I also get a multi-point inspection including brake condition and thickness, battery charge and condition, etc. unless such filter is possible, after all there has to be a FL-400 filter? It is admissible? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 7, 2015 Report Share Posted January 7, 2015 This thread says the 500s should fit if build date is after Jan 16. 2009: http://www.fordedgeforum.com/topic/438-oil-filter/ Yours is not, so I would stick with the 400s filter. Not sure what the practical differences would be between the 400 & 500 filters. Could be drainback valve pressure, burst pressure, capacity, etc. FL400s: 2.98 inches in diameter, 4.72 inches in height. Dry weight: 0.8 pounds. Thread size: 3/4-inch. Relief valve pressure: 14 psihttp://www.ehow.com/list_7846289_specifications-motorcraft-fl400s-filter.html 1 Quote Link to comment Share on other sites More sharing options...
EDST777 Posted January 7, 2015 Report Share Posted January 7, 2015 Thanks ! Quote Link to comment Share on other sites More sharing options...
