2008 EDGE Died on way to work!! Getting FUEL n SPARK
spoontuned
Could be any number of things. What is the recent service history on your vehicle?
You say you are getting fuel pressure and spark. Could you tell us the readings and how/where you took them?
A sensor like the crank position sensor or cam position sensor could have failed. When you try to start the Edge, do you get erratic tachometer readings, does it stay at 0, etc.? Does it seem to crank normally?
Have you checked battery voltage? Any signs of corrosion, dripping on any wires underneath?
Any fluid leaks? All fluid levels OK?
Did you try starting with transmission in both P and N?
PCM could be fried, but not sure that would cause a lack of the CEL or codes.
Quite possible you have the infamous throttle body problem. You will have to insist on that being checked/replaced, and to date there has been a backorder on this part.
This thread might give you some ammo to back you up:
http://www.fordedgeforum.com/topic/3586-2007-edge-unexplained-stalling/
Edited by WWWPerfA_ZN0W
