Back seat wont fold down/un-latch
My 60 portion of the back seat won't un-latch anymore.
If I press the button in the cargo area I can hear the mechanism but nothing happens.
If I pull up on the manual lever next to the seat nothing happens.
There is normal tension on the lever, but it doesn't release the seat.
Anyone else experience this? Thoughts?
  • 2 years later...
I have a 2011 with 43,800 miles on it. The so called "Easy fold" seat nor the manual handle will release the seat to fold down. I can hear the release cable motor operate, but doesn't release. I figure its actuator is broke and I'll have to take the darn seat out, and get a new actuator from Ford parts, which is probably the same junk as the orig.
Did not use or abuse the "easy fold" seat fold release but it seems from what I hear, the release mech is a poor design - probably not able to take the heavy spring pressure on the seat back, even with normal use over time. Anybody know if there was an improvement /upgrade to this problem? I check TSB's and haven't found anything.
The small side continues to work . Thanx
Thanks for the info and tips enigma-2 - so this actuator actually comes with instructions??? I figure I best take the seat out first and check everything.
Right now - manual handle does move up and down like its not connected to anything - also- cable motor runs -sounds like nothing is connected---so indeed could be a broken cable.
Ah - Great Lakes ILL !! I went thru USN boot and then schools at Camp Porter and Moffett - arrived there by train (from NY to Chicago to Gr Lakes) on a cold Jan day in 1966 - found myself in the 7th fleet -on a heavy Cruiser. afterwards. tours of duty in Nam.
Edited by EdgeeOne
After typing it all up I just somehow erased my detailed fix. so I will have to come back, but turns out cables were good - just a clip that goes on end of the long cable which connect to the manual release lever. The clip was broken -- once I figure out how to put some photos up I will do so. The part is ordered which is
Seat Back Actuator Rod Clip
Part #: <61479
That's great, easy fix. Good to know, photos may help someone else with this problem in the future.
This post will describe how to add photos (I use Photobucket).
http://www.fordedgeforum.com/topic/13034-how-to-use-this-site-post-photos-your-control-panel-etc/?do=findComment&comment=101627
Edited by enigma-2
broken clip E
End Of cable W O clip
40% seat with Ok clip
60% seat removed
2011 Edge 60% seat out of vehicle
Above photos (which I can't get to just display across the window.) I posted to Gallery show the 60% seat removed, click on any and you will go to the album. The broken plastic seat back release pin actuator rod - p/n 61479 which is on order. seems to me a little dab of silicon grease should help.. it was totally dry and there is a lot of spring tension this cable has to pull the actuator from. I'll report back after I install the part and see if it works ok.... ;)
Edited by EdgeeOne
Great pictures, thanks. Glad you figured it out and it wasn't expensive. Remember not to change the position of the seat or put ant pressure on it (laying it upside down to put anything on the seat) while it's out of the car; unless you check the recliner synchronization, or it may fail later on. Service manual makes a "big" deal on this.
  • 5 months later...
SECOND ROW MANUAL FOLDING SEATS WILL NOT FOLD UP/DOWN OR ARE INOPERATIVE
FORD: 2011-2014 Edge
ISSUE:
Some 2011-2014 Edge vehicles may exhibit second row manual folding seats that will not operate properly or are in inoperative.
The seat may be stuck in the fully up position.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Remove the affected seat, refer to Workshop Manual (WSM), Section 501-10.
Remove the inboard lower side shield to gain access to the cable and clip at the bottom of the seat backrest frame.
Is the clip unattached or missing? (Figure 1)
clip
Figure 1
Yes- replace the clip with a new clip and reattach it to the seat bottom frame.
No replace the seat backrest frame, refer to WSM, Section 501-10.
Reinstall the affected seat. Refer to WSM, Section 501-10.
PART NUMBER PART NAME
78613A38 40% Backrest See Parts Catalog For Correct Color
78613A39 60% Backrest See Parts Catalog For Correct Color
FT4Z- 9661479-A Clip
After suffering through the 'limp mode' throttle body repair on my 2016 Edge, I remembered reading something about rear seats not folding on this forum. My 12 month, 12,000 mile bumper to bumper expires 9 April, so I went out and checked my folding seats for the first time. Right side folds correctly when pushing the button, Left side does not fold when pushing the button. Back to the dealer Monday. I should note my Edge also has the overly sensitive brake booster, which is on order through the dealer. Another disappointment. My 'virgin' Edge is no longer. However I still have the excellent ride and handling remaining to enjoy.
I wanted to add that I was able to replace this clip without removing the back seats. I popped out the cargo management cover and the cargo bin on the right side, then used a T20 Hex key to remove the screws holding the cover over the spring assembly.
The screw facing the rear was easy to remove. After that I pulled back the cover and pulled the spring while pressing the power assist button to cause the seat to fold down, making the second screw more easily accessible. Push the cover both forward and down to unhook it from the seat bottom, pop the new clip into place and pull back the spring to get the cable end into the opening. I have basketball player sized hands, so I think this would be even easier for a normal person.
*Edit, right vs left.
Edited by mikrsmith
