Center hanger bearing drive shaft?
skeczan
Hi after just going to mechanic for oil change discover the center hanger bearing (rubber piece) on the drive shaft is deteriorating. He calls around for part to discover you can only buy whole drive shaft for $1200. I find it maddening that I cannot get just the part I need, any idea where I could find just this part? Any advice appreciated! Thanks!
Do you mean the Center Shaft Support Bushings? They are available separately for less than $12 a set. Looks like you need 4 sets per driveshaft? Post a request for Benny in the LevittownFordSuperCenter thread if you like. Local dealer should be able to assist you.
Your Search Results 4 Parts found for 2008 Lincoln MKX > Driveline and Axles > Drive Shaft
Part Number Part Name and Description Price (MSRP/List) Your Price
(as of 1:14PM EDT)
4A169A Drive Shaft Center Support Bushing $8.00 $6.80
4A169B Drive Shaft Center Support Bushing $4.00 $3.40
4R602 Drive Shaft $790.25 $671.71
(Rear) Vehicle Build Date before: 7/22/2008
4R602 Drive Shaft $492.78 $418.86
(Rear)Vehicle Build Date after: 7/23/2008
Edited by WWWPerfA_ZN0W
  • 10 months later...
  • 3 months later...
  • 1 year later...
