teknowiz Posted September 9, 2013 Report Share Posted September 9, 2013 (edited) Need some info on where air intake by for the A/C is located when in recerculation mode on 2011 MKX. I have an issue with a odour that comes from the vents and am trying to eliminate it by spraying some lysol into the intake. Edited September 9, 2013 by teknowiz Quote Link to comment Share on other sites More sharing options...
akirby Posted September 9, 2013 Report Share Posted September 9, 2013 Just guessing I would say underneath the glove box on the passenger side. Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 9, 2013 Report Share Posted September 9, 2013 I believe its behind the glove box, top side. If you remove the cabin air filter, you'll see the fan immediately under it. Spray their if you like. Also, when was the last time you changed the filter? the odor might be from something stuck on it. Quote Link to comment Share on other sites More sharing options...
teknowiz Posted September 9, 2013 Author Report Share Posted September 9, 2013 Thanks, will check those locations. Filter was changed about 3 months ago. Initially I thought it was the filter as well which is why I had it repalced 3 months ago but the moldy smell still persists. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 9, 2013 Report Share Posted September 9, 2013 The A/C drain may be clogged. There is a thread or two about the fix if this is the case. Quote Link to comment Share on other sites More sharing options...
Limited59 Posted September 9, 2013 Report Share Posted September 9, 2013 I have a mouldy smell as well in my MKX. It's worst immediately on startup and usually goes away. I've never had it happen to any of my previous vehicles but I think it started after I got home one night when it was extremely hot and humid outside and immediately shut the garage door. I had it on recirc so I think some moisture got trapped in the hvac and caused some mildew. When it's hot I usually leave the door up for a while because my garage is so tight but not that night because it was late. Four months old and 2,000 km on it. I researched online and the suggestion is normally Lysol in the outside cowl vent on the passenger (?) side. Of course that won't work with recirc on. Also check to see if the vent tube is clogged. I don't think mine is because there's always a puddle under it on hot days. Quote Link to comment Share on other sites More sharing options...
teknowiz Posted September 10, 2013 Author Report Share Posted September 10, 2013 The tube is not clogged since I also see the puddle. Already tried Lysol on cowel outside front passenger section under the hood. Checked dash on passenger side and didnt see any intakes. Took glove box off and I think recircualte mode intake is diectly below the filter but too many exposed wiring there for me to safely spry lisol with engine on. I did spray a bit below that general alrea with it on max ac mode so will see if this helps it at all. From the searches on a few threads here I think the issue is mold or trapped water in the condensator or blower and would need to clean that to fully get rid of the smell. Quote Link to comment Share on other sites More sharing options...
1duFos Posted September 10, 2013 Report Share Posted September 10, 2013 I have owned cars with A/C since 1983 and never had an issue with moldie smells. What I do before shutting the car off, would probably work with the engine off, I raise the temp to high heat and let it run for a minute with the A/C still on, I think this will also work with the A/C off. This dries out the condensor etc. so no mold will grow. Quote Link to comment Share on other sites More sharing options...
