Nexus Posted September 6, 2013 Report Share Posted September 6, 2013 (edited) So I finally pulled the trigger on 2 pairs of Infinity Kappa 682.11CF after "extensively" reading this forum. I tried calling a few places to get a decent amp and one guy offered me this one for $400 CAD. He mentioned that an under powered amp would be better for the speakers as well. Alpine PDX-5 (getting rid of old stock) http://www.alpine-usa.com/product/view/pdx-5/default My concern is this amp would/is probably underpowered when taking into consideration the specs of the speakers + my sub. The sub I have is the 10" Alpine Type S @ 500W RMS. What are your thoughts on these? MRX-V70 http://www.alpine-usa.com/product/view/mrx-v70/Specs and Alpine PDX-V9 http://www.alpine-usa.com/product/view/pdx-v9 Please also advise on any other amps that you deem fit for my settings. I'd really appreciate it. Edited September 12, 2013 by Nexus Quote Link to comment Share on other sites More sharing options...
abhp06 Posted September 6, 2013 Report Share Posted September 6, 2013 I would go with the Alpine PDX-V9 only because the 1 channel has more power but the issue with using 4 channel amps is you cannot seperate your door speakers from sub. Only because your crossover is either on HPF, LPF, or Full. That's why I got two seperate amps so i can independently control them. Plus the rear door speakers bring more mid bass range while fronts will be full or high range. This is why I had to had a subwoofer into the mix. Quote Link to comment Share on other sites More sharing options...
jmacd27 Posted September 6, 2013 Report Share Posted September 6, 2013 Where did you find the Kappas up here in Canada? I've been looking online to buy 2 sets, but haven't found any yet. Quote Link to comment Share on other sites More sharing options...
Nexus Posted September 6, 2013 Author Report Share Posted September 6, 2013 On 9/6/2013 at 5:57 PM, abhp06 said: I would go with the Alpine PDX-V9 only because the 1 channel has more power but the issue with using 4 channel amps is you cannot seperate your door speakers from sub. Only because your crossover is either on HPF, LPF, or Full. That's why I got two seperate amps so i can independently control them. Plus the rear door speakers bring more mid bass range while fronts will be full or high range. This is why I had to had a subwoofer into the mix. Thanks for your input abhp06. I appreciate it On 9/6/2013 at 6:51 PM, jmacd27 said: Where did you find the Kappas up here in Canada? I've been looking online to buy 2 sets, but haven't found any yet. I purchased them from Sonic Electronix http://www.sonicelectronix.com/item_60698_Infinity-Kappa-682.11cf.html They gave me a discount of $17 per pair on top of the final price.. You have to place your order over the phone though. Quote Link to comment Share on other sites More sharing options...
jmacd27 Posted September 6, 2013 Report Share Posted September 6, 2013 On 9/6/2013 at 7:03 PM, Nexus said: I purchased them from Sonic Electronix http://www.sonicelectronix.com/item_60698_Infinity-Kappa-682.11cf.html They gave me a discount of $17 per pair on top of the final price.. You have to place your order over the phone though. Thanks for the response. I did look at buying them from them, but their web site said the can only ship Infinity products to US only. I'll have to give them a call and get a set. Now to save up for a Stealthbox and a couple of amps. Let me know how your install goes. Quote Link to comment Share on other sites More sharing options...
Nexus Posted September 12, 2013 Author Report Share Posted September 12, 2013 They are currently on sale @ Sonic Electronix http://www.sonicelectronix.com/item_60698_Infinity-Kappa-682.11cf.html Get the 2nd pair off @ 50%.. not a bad deal.. on 2 left apparently Quote Link to comment Share on other sites More sharing options...
Nexus Posted October 14, 2013 Author Report Share Posted October 14, 2013 I just purchased the Alpine Pdx-v9 (5 channel amp). Will I be required to buy an (LOC) as well? if so, which one would you recommend? How many channel? By installing an LOC, would I still get full power from the amp? I don't have the sony system and I'm planning to keep the stock HU. Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Nexus Posted March 25, 2014 Author Report Share Posted March 25, 2014 (edited) I know this is an old thread, but i took my time to buy and put things together. I did a lot of research and before i go ahead and do the installation this spring, i want to make sure I have everything that i need to move forward. Here's a list of things that I have at the moment Alpine PDX-V9 Audiocontrol LC7I NVX XKIT44 Infinity Kappa 682.11CF (already installed in all 4 doors) I will be tapping into the speaker wires at the door (front and rear) instead of going behind the head unit. I'm also planning to run new speaker wires from the amp to the speakers. I am aware that our alternator is 150 AMP but considering that my 5 channel amp is 800 W RMS/1600 W max power, will i be required to install a capacitor? I believe that with the system installed, i will be needing at least 100 AMP from the alternator. This is the calculation I've been using (800 RMS (AMP) + 400 (sub) / 12) = 100 AMP (not sure if i should have added the sub in this calc) . Will that put too much strained on the alternator? Finally the speakers are 2 ohm and the sub i have is 4 ohm, will that be a problem? Pls advise Edited March 25, 2014 by Nexus Quote Link to comment Share on other sites More sharing options...
Nexus Posted March 28, 2014 Author Report Share Posted March 28, 2014 no one ? anyone? bump..any advice would be appreciated Quote Link to comment Share on other sites More sharing options...
