HTW750 Posted September 4, 2013 Report Share Posted September 4, 2013 Just got this message this morning for the first time: Navigation SD Card Fault Please insert a valid SD card I have removed and reinserted the card that came with the Edge in February. Any suggestions. Quote Link to comment Share on other sites More sharing options...
tmbubell Posted September 4, 2013 Report Share Posted September 4, 2013 Just got this message this morning for the first time: Navigation SD Card Fault Please insert a valid SD card I have removed and reinserted the card that came with the Edge in February. Any suggestions. I had the same thing happen to me on Saturday August 31, 2013 - I took the card out to make sure nothing had bumped it, then re-inserted it. The same error came up at first, then the system ran through a couple of checks and it started working again. Still working Quote Link to comment Share on other sites More sharing options...
fledgex Posted September 5, 2013 Report Share Posted September 5, 2013 Do you both have the updated A4 SD card? Quote Link to comment Share on other sites More sharing options...
tmbubell Posted September 5, 2013 Report Share Posted September 5, 2013 (edited) Do you both have the updated A4 SD card? Yes , I do and i'm running the new 3.6 software Everything has been fine since the update except for this little hicup Edited September 5, 2013 by tmbubell Quote Link to comment Share on other sites More sharing options...
HTW750 Posted September 5, 2013 Author Report Share Posted September 5, 2013 Yes I have the A4 card. They have recommended an update. Quote Link to comment Share on other sites More sharing options...
sappermedic636 Posted March 27, 2014 Report Share Posted March 27, 2014 Just bought a 2012 SEL with Nav but no SD Card. Ford sent the new A4 card but still getting the "insert valid SD card error" is there something else I have to do? Quote Link to comment Share on other sites More sharing options...
ls973800 Posted March 27, 2014 Report Share Posted March 27, 2014 (edited) I believe the A4 card will only work if you have version 3.6.2 or the previous update. Is your SYNC running the latest update? Perhaps your unit is still set up for the A3 card. Edited March 27, 2014 by ls973800 Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted March 28, 2014 Report Share Posted March 28, 2014 Just bought a 2012 SEL with Nav but no SD Card. Ford sent the new A4 card but still getting the "insert valid SD card error" is there something else I have to do? I can check to see if your software is up-to-date, sappermedic636. Just shoot me a PM with your VIN. Like ls973800 stated, your MyFord Touch software may be out dated, but that's an easy fix. Rebecca Quote Link to comment Share on other sites More sharing options...
Lori Beauchamp Turner Posted May 20, 2014 Report Share Posted May 20, 2014 I am having the same issue. I just bought a 2012 Ford Edge Limited. It has factory installed navigation, but the case that held the A1 card was missing. I bought a A4 card and got "insert valid SD card error" every time I tried. Is there something I need to update first? Thanks Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted May 20, 2014 Report Share Posted May 20, 2014 (edited) Hi, Lori,Congrats on your new-to-you Edge! It sounds like you are several MyFord Touch updates behind. Shoot me your VIN in a private message so I can confirm, and we can go from there.Rebecca Edited May 20, 2014 by FordIVTteam Quote Link to comment Share on other sites More sharing options...
Lori Beauchamp Turner Posted May 20, 2014 Report Share Posted May 20, 2014 Hi Rebecca, I called the 800 number and talked to a very helpful lady named Kim. I need to do the updates first and then try the SD card. I will do that tonight. If I still have problems I will let you know. Thanks, Lori Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted May 21, 2014 Report Share Posted May 21, 2014 Sounds good to me! Rebecca Quote Link to comment Share on other sites More sharing options...
lhager08 Posted September 2, 2015 Report Share Posted September 2, 2015 Receiving the message: Navigation SD Card Fault. Please insert a valid SD card. Is this something easy to fix or should I bring it to the dealership for repair since it's still under warranty? Thanks! Quote Link to comment Share on other sites More sharing options...
akirby Posted September 2, 2015 Report Share Posted September 2, 2015 Try removing and reinserting. Quote Link to comment Share on other sites More sharing options...
Greg Pepper Posted February 1, 2016 Report Share Posted February 1, 2016 I had this same problem with my 2014 edge sel. I would get the navigation fault message every so often. Usually I would just take the card out and put back in and the navigation would load back up again. But just today that happened and when I went to put the card in and out it wouldnt fix the problem.. It still says "insert sd card" I tried a few times and also tired to turn off my car and it still won't recognize the card. How can I fix this??? (I have the A5 card) Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted February 2, 2016 Report Share Posted February 2, 2016 Hi Greg Pepper, Please remove the SD card and try a master reset: http://owner.ford.com/sync-technology/perform-master-reset-sync-myford-touch I also recommend checking your Owner account for updates: https://owner.ford.com/tools/account/how-tos/keep-your-sync-up-to-date.html Keep me posted. Shaay Quote Link to comment Share on other sites More sharing options...
wmc6632 Posted August 29, 2016 Report Share Posted August 29, 2016 I have a 2015 Edge (the new model) and it's still under warranty. I just got the Nav SD Card fault that tells me to insert the SD Card. Removing and reinserting doesn't help. I tried a master system reset and that didn't work. The Ford Owner websites says my software was last updated in May 2015 (when the car was built) and that it is the latest. Appreciate any feedback on what to do next. Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted September 3, 2016 Report Share Posted September 3, 2016 I have a 2015 Edge (the new model) and it's still under warranty. I just got the Nav SD Card fault that tells me to insert the SD Card. Removing and reinserting doesn't help. I tried a master system reset and that didn't work. The Ford Owner websites says my software was last updated in May 2015 (when the car was built) and that it is the latest. Appreciate any feedback on what to do next. Hey wmc6632, I suggest taking the vehicle to the dealer and have them look to see if you received a faulty SD card. If you did, contact HERE Maps to have them replace the card with a functioning one. You can contact HERE at 866-462-8837 or at www.navigation.com Cara Quote Link to comment Share on other sites More sharing options...
jhahnwx Posted September 16, 2016 Report Share Posted September 16, 2016 Similar issue with me. Got the updated maps in an SD card in April and installed. All worked well for a few months and got an error one day. At next vehicle power up it seemed to recover and it seemed like the display changed a little so figured it had downloaded some sort of update. Last weekend it failed completely and screen message said insert SD card. Ejected and reinserted multiple times to no avail. Did master system reboot to no avail. Emailed Fordnavigation.com folks from which I purchased it and after several days they have issues an RMA but will not provide a new SD Card until they get the old one. That is MAJOR foul in my opinion. Unhappy customer here. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 16, 2016 Report Share Posted September 16, 2016 Can't you use the old card in the meantime? Or does it get the same sd card fault message? Quote Link to comment Share on other sites More sharing options...
jhahnwx Posted September 16, 2016 Report Share Posted September 16, 2016 Can't you use the old card in the meantime? Or does it get the same sd card fault message? I discarded the old one when the new one was installed and worked ok. Wish I had kept it. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 16, 2016 Report Share Posted September 16, 2016 Oops Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 16, 2016 Report Share Posted September 16, 2016 Go down to your dealer and ask if you can try the SD card in one of their used cars. If it works, you have a ACM faiure. If not, the card got zapped and needs to be replaced. Quote Link to comment Share on other sites More sharing options...
Waynesworld Posted September 27, 2016 Report Share Posted September 27, 2016 I have a 2015 Ford Edge SEL that has a problem with the navigation SD card faulting out. It currently has the SD 6 card in it from when I bought it. It seems to act up more when it is sitting outside in the heat then any other times....... How do I fix this problem ? Thanks , Wayne Quote Link to comment Share on other sites More sharing options...
Burrcold Posted September 27, 2016 Report Share Posted September 27, 2016 Bring it to the dealer and get them to figure it out. Quote Link to comment Share on other sites More sharing options...
