torque specs
brantlyj
Here is an excerpt from the manual.
Instructions say to break the control arm from hub assembly at the ball joint. If you can do it at the control arm and leave the ball joint intact, seems even better!
Have fun.
Thanks for the scan. It says to refer to the "procedure" for the hub nut torque values. Would you be able to scan that part as well? I would really appreciate it.
I was going to go with the lower control arm only because I found a How-To for a CV replacment on a Ford Escape. I figured it would be similar on the Edge. Once I get in there I'll take apart whatever is appropriate.
Here is the procedure for the front left and right half shafts. Post pictures please.
Ford Edge Half Shafts 2.pdf
Thanks, you rock. :worship:
This looks like a super simple job. I'll try and get some photos. I should have the shaft in a few days but due to my schedule probably will not be able to work on it for a few weeks. Hopefully my shaft dosn't implode before then. ;)
Edited by brantlyj
