RKedge Posted August 26, 2013 Report Share Posted August 26, 2013 Brand new, 400 miles, transmission fluid leak, small spot on driveway about 5 inch diameter, bead of fluid at bottom of transmission by long seal-runs front to back. Anyone know what the problem is or have had the problem? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 26, 2013 Report Share Posted August 26, 2013 (edited) AWD? Could be the classic PTU seal leak, yes, too early, but possible. EDIT: Never mind, just saw you have a FWD in your other post. Might be a loose plug, just needs tightening? Edited August 26, 2013 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
RKedge Posted August 26, 2013 Author Report Share Posted August 26, 2013 I sure hope so... Quote Link to comment Share on other sites More sharing options...
Larry Posted August 26, 2013 Report Share Posted August 26, 2013 I would be knocking on the dealers door. Larry Quote Link to comment Share on other sites More sharing options...
banditsrt Posted August 26, 2013 Report Share Posted August 26, 2013 I've got a leaky transmission too. Just over 3,000 miles. We dropped our SE off at the dealer last week. Since we're in Germany, it might take up to 3 weeks to fix! 1 Quote Link to comment Share on other sites More sharing options...
RKedge Posted August 30, 2013 Author Report Share Posted August 30, 2013 Well...better than I thought, ended up being an axel seal, could have been something more catastrophic... Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 30, 2013 Report Share Posted August 30, 2013 Seems like a lot of these faulty seals continue to get installed at the factory. The repair should hold up better, though. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted September 22, 2013 Report Share Posted September 22, 2013 My wife has told me that she's seen a leak under the Edge. I plan to have this and a litany of other things checked out while I still have a warranty. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 22, 2013 Report Share Posted September 22, 2013 GL with that list, Prinzll. Hopefully the dealer will see the items as "far gone enough" to service them rather than tell you to "come back later" (after warranty expiration). Quote Link to comment Share on other sites More sharing options...
