limited with 22inch rims
firemanmfd
My understanding is that the bolt pattern is the same so there shouldn't be a fit issue. Your mileage will decrease slightly (as will off the line performance) due to the increased force necessary to get your momentum going on the bigger rims but it shouldn't be much. Also, your speedometer will be a slightly off and may need adjusted (not sure if any tuners exist or if the dealer would have to do this) due to the increased overall size of the new rims/tires versus your old one. If you previously had 20s it'll be a little off but if you have 18s it could vary a few MPH+.
Because of the way Ford has selected the tire sizes from the factory, the 20 and 18 inch wheels are almost identical regarding speedometer readout, revolutions per mile, and height. There is hardy any noticeable difference between the factory 20 and 18 inch wheel/tire combination.
To see what the differences are stepping up to a 22 inch wheel, use this tire calculator. Input the proper size tires or other optional sizes to see the differences.
http://www.1010tires.com/Tools/Tire-Size-Calculator
Don't forget that since you have a 2011 model, your hub wheel opening is smaller than the 2010 and older models. You can put those wheels on if you use the proper hub centric rings that are available. 2011 and newer models will be a direct fit. Bolt patterns on all years are the same.
  • 7 months later...
