Ignition Coil Fauilure
susmdun
Has anyone who has had the ignition coil failure had anymore problems from your edge since fixing it? We are now having to replace the catalytic converter after having all ignition coils, spark plugs, upper intake gaskets, and pcm. How is your car running after having this repair done for a burnt ignition coil and internal driver fault of pcm? Did you have to replace the cat. also.
