Radiator Cooling Fans
EDGE'08
Yes, both should be running..... likely culprit is the fan control module, but you could have a bad motor as well. Unplug the A/C high pressure siwtch (in the A/C high pressure line near the airbox), start engine and wait a minute or so, both fans should default to the HI setting. If not or only one turns on, start checking voltage at the fan itself
