Cutoff point in changing options
According to Research Maniacs once the VIN is created no changes can be made to that vehicle.
http://www.researchmaniacs.com/Ford/TrackFactoryCarOrders.html
quote...
"Verify the information
This may be a good time to double check that all the information is correct. Although, since Ford assigned a VIN, you cannot make changes at this time.."
However, theoretically an order can be cancelled anytime before the vehicle is built and a new order created.
Effectively you would then be getting a different vehicle.
Not sure how easy it would be to make that happen though, Probably depends on the dealers relationship with Ford scheduling and I imagine they would be more likely to authorise a change if you were adding options and paying more rather than removing them. It would likely push back your build and delivery date too.
I bought mine in mid April but it wasn't delivered till late June.
I changed the colour to Ruby Red the day after the order went into the system and I'd signed the 'All sales final' paperwork but that was long before the VIN was created. It was in the system over a month before they created a VIN. (Possibly because of a Ruby Red paint shortage I was told)
Hope that helps
GG
