candurin Posted July 16, 2013 Report Share Posted July 16, 2013 Now, if we could develop something for the vanity lights...... http://www.vleds.com/5k-white-3-led-wedge-base-dash-light-bulbs-37-74-1-pair.html Quote Link to comment Share on other sites More sharing options...
PrinzII Posted July 18, 2013 Report Share Posted July 18, 2013 http://www.vleds.com/5k-white-3-led-wedge-base-dash-light-bulbs-37-74-1-pair.html What would be nice is if they had a setup that used the same cartridge style but had some sort of reflector to fill out the housing so the light is spread evenly. As it sits, there's a hot spot and it's usually in my wife's face. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted July 19, 2013 Author Report Share Posted July 19, 2013 just put these in the front lights in the cab. already more of a yellow color now instead of the blue it was before....now to wait till it gets dark to comparehttp://www.ebay.com/itm/2X-6000K-6-LED-5630-SMD-CANBUS-ERROR-FREE-T10-194-168-W5W-PROJECTOR-LENS-BULBS-/221255947917 these are what was in ithttp://www.ebay.com/itm/NEWEST-OSRAM-CHIP-2PC-5W-JDM-7000K-WHITE-LED-SMD-T10-194-168-W5W-LIGHT-BULBS/221253297231 Quote Link to comment Share on other sites More sharing options...
CMOS Posted July 21, 2013 Report Share Posted July 21, 2013 I've got most of the car upgraded to LEDs and the thing is super bright now. However I've started taking the family to drive in movies, now when I open the door to the car during the movie, the thing lights up like the sun. 1 Quote Link to comment Share on other sites More sharing options...
pedro2u Posted July 28, 2016 Report Share Posted July 28, 2016 After the wow factor of LED puddle lamps, I've moved inside. I bought T10 LED's for the front map lights, but when I pulled it down to install them, they were already LED's! Wondered why they were so much brighter than the rear So in the rear interior/map light, those festoon type had not been changed. I installed these in all 3 spots (2 map, 1 courtesy) and WOW! https://www.amazon.com/gp/product/B00ZJF7GTY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 One note from earlier threads though. They were flickering a bit, so I had to take them out, squeeze the contacts in the housing, and snap the LED's back in. Perfect now 1 Quote Link to comment Share on other sites More sharing options...
rsto Posted September 26, 2016 Report Share Posted September 26, 2016 I purchased some led festoon type bulb to replace mine in the rear but cant seem to get them to stay on. I never had any issues with the stock bulbs but since I made the swap when I hit a bump or anything they stop working. I checked it out the other night and when I shut the either back door they flicker almost as if it losing its connection. When I got in this morning to come home from work they were on, after driving home and having to go over a few speed bumps before parking and opening my door again, they weren't on. I leaned back and tapped on the roof a few inches in front and they came on. Im not sure if when I took the old ones out I loosened the metal clips or what but do either of you have any suggestions so they can stay on everytime i open the door? I had someone suggest using electrical tape to hold em in as well as wrapping the ends with a little bit of aluminum foil. Im against that for obvious reasons and don't want electrical tape to melt and get nasty when I replace them again later on. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted September 26, 2016 Report Share Posted September 26, 2016 I had this happen in my f150. It's exactly what you think the clips are loose the bulb moves around and you get flickering. I actually just bent one clip in a tiny bit with some needle nose and popped bulb back in never had an issue again. 1 Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted September 27, 2016 Author Report Share Posted September 27, 2016 you can bend them a little, in all honesty, I added some foil. This isn't a light that stays on 24/7. Usually only on for less than a minute or two for entry/exit 1 Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted September 27, 2016 Report Share Posted September 27, 2016 I'm against using foil for electrical conductivity. I know this is a low power LED, but I've seen somebody try to use it elsewhere before and basically the microwave blew up like a bomb. He was an idiot and trying to bypass a fuse to see what was wrong. Like I said I'm sure it's a bit different for an LED but bending the post a tiny bit seems like a better idea than wrapping a connection with a loose thin sheet of aluminum. Quote Link to comment Share on other sites More sharing options...
rsto Posted September 27, 2016 Report Share Posted September 27, 2016 I'm against using foil for electrical conductivity. I know this is a low power LED, but I've seen somebody try to use it elsewhere before and basically the microwave blew up like a bomb. He was an idiot and trying to bypass a fuse to see what was wrong. Like I said I'm sure it's a bit different for an LED but bending the post a tiny bit seems like a better idea than wrapping a connection with a loose thin sheet of aluminum. I agree with you totally on this. If its as simple as bending a clip back in place than that's what ill try when I have a chance to do so. Just the idea of adding something that's not supposed to go there and adding to it that it deals with electrical just scares me. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted September 29, 2016 Report Share Posted September 29, 2016 Yea, I mean yes it will conduct electricity but so does a potato...I don't see anybody using a potato to connect that last few inches of a circuit. Some things are better left to original use. Some cheap foil just does not seem to be the way to go in a vehicle. I'd even dare to wonder what happens when a kid bumps the switch back there to always on, and that tin foil light is on over night. Quote Link to comment Share on other sites More sharing options...
