Winshield fogging with A/C and warm temps
Hi all,
Curious how many drivers experience this...
Have a '13 Edge Limited, and have been having an issue with the windshield fogging up when the A/C is on and the outside temp is relatively high (mid 70's to 80's). A/C usually set to about 72 or so.
Fan is set to blow at foot level, but I'm seeing moisture / fog build-up on the outside of the windshield - almost like the vents are allowing the cold air to leak through to the windshield and causing the outside moisture to condense on the windshield. Not sure that I've seen any other cars with the same problem.
Wondering if this is common or I should ask my dealer's service department to dig into it. Don't want to have them pull the dash apart if they can't fix it.
Thanks.
