How To Install Replace Turn Signal Wiper high beam lever
I have a 2008 ford edge. My daughter wanted to pretend she was driving and she broke the turn signal, wiper , high beam lever on the steering column. I think there is only a couple switches holding the lever, but I need help how to take off the plastic covers around the steering column so that I don't break them.
Any help in removing the 2 plastic covers around the column would be greatly appreciated.
Just in feeling around on my column, I felt two bolts on the bottom side of the column near the base of the steering wheel. Have you tried loosening those to see if the two halves start to come apart? Also, turn the steering wheel to see if it exposes any screws on the column.
