andbudzi Posted June 29, 2013 Report Share Posted June 29, 2013 (edited) I would like to know torque specs for front right AWD control arm mounting bolts - - ? control arm to hub bolt (boljoint) - - ? axle to bub bolt - - 258 ft-lb - please confirm ... spindle to shock - - ? my edge is 2013 but it usse same control arms / suspension parts as 07 and up Edited June 29, 2013 by andbudzi Quote Link to comment Share on other sites More sharing options...
autom8r Posted June 30, 2013 Report Share Posted June 30, 2013 andbudzi: Front Suspension Information attached. I don't see anything as high as 258 ft-lb. Look out for the in-lb ones. Stuff will start breaking if you read it wrong. Have fun! Ford Edge Front Suspension.pdf 1 Quote Link to comment Share on other sites More sharing options...
TOMBSTONE Posted March 4, 2015 Report Share Posted March 4, 2015 Need torque specs for rear upper control to hub bolts on 2013 Ford Edge and rear sway bar brackets ? Thanks... Quote Link to comment Share on other sites More sharing options...
