how to change high pressure power steering line on 2007 edge
hdmapp
hey guys so unfortunately my power steering line has rusted out and finally got a hole small enough to leak. Its quite a stupid design, the location that rusted runs beside the oil pan and is wrapped in aluminum. The problem is water builds up inside and sits there eating away at the metal hose.
Long story short does anyone have a digram or how to guide on changing this hose? it looks like the one in link attached
http://www.oreillyauto.com/site/c/detail/PPS0/92233/02846.oap?year=2008&make=Ford&model=Edge&vi=1441679&ck=Search_02846_1441679_-1&pt=02846&ppt=C0031
any help is good help! thanks
I can't say I've been there...yet. Here is what the manual mentions about the replacement of the high side hose, which matches the one you show from O'Reilly. I'm not clear on why the wiring around the PCM and the purge valve needs to be moved out of the way. Seems like it's all accessible from underneath the car.
I added some other details of I found in other parts of the manual too.
Good Luck!
Ford Edge Power Steering HP.pdf
Ford Edge Power Steering HP2.pdf
Edited by autom8r
