DanM Posted June 19, 2013 Report Share Posted June 19, 2013 The is no such thing as a stupid question... Only inquisitive idiots. The wiring harnesses offered by Curt and others require an power connection terminated at the battery. Is it possible to simplify the process and splice into the outlet in the rear left panel,d which has to be opened anyways? Quote Link to comment Share on other sites More sharing options...
autom8r Posted June 19, 2013 Report Share Posted June 19, 2013 I would, why not? There is also the relay in the same location [151-17] on connector C474 that serves the power outlet. Look for the yellow wire with a red stripe, splice into that one. It is runs straight to fuse 66, 20A at the battery junction box in front. Install the inline fuse with the trailer connection circuit. Attached is a diagram for your use. Good Luck! Ford Edge Rear Power Outlet.pdf 2 Quote Link to comment Share on other sites More sharing options...
DanM Posted June 19, 2013 Author Report Share Posted June 19, 2013 I would, why not? There is also the relay in the same location [151-17] on connector C474 that serves the power outlet. Look for the yellow wire with a red stripe, splice into that one. It is runs straight to fuse 66, 20A at the battery junction box in front. Install the inline fuse with the trailer connection circuit. Attached is a diagram for your use. Good Luck! Thanks for the diagram and info! That saves me a ton of time testing and research as well as time under the car snaking a wire to the battery. The control module does not consume that much power that it needs it's own feed. Dan Quote Link to comment Share on other sites More sharing options...
akirby Posted June 19, 2013 Report Share Posted June 19, 2013 It all depends on the required amperage. You don't want to use a 10 amp circuit for a 15 amp accessory. Quote Link to comment Share on other sites More sharing options...
candurin Posted June 19, 2013 Report Share Posted June 19, 2013 Fantastic!!! I've been wanting to install the ford OEM wiring harness and this saved me a LOT of trouble! Quote Link to comment Share on other sites More sharing options...
kc300c Posted June 19, 2013 Report Share Posted June 19, 2013 Just wanted to second autom8r's recommendation to include the properly sized in line fuse as well as akirby's note to tap a circuit that is rated for your load. Better safe than sorry. Good luck with the project. Quote Link to comment Share on other sites More sharing options...
