Mustang 19's will they fit.
RobbN
Local guy selling 2011 Mustang GT rims
they are 19" rims and looking it up on tire rack.com looks like the offset and size are the same as my SEL 2011 edge.
differences - for my EDGE tirerack for a 19" rim tirerack recommends 235/55/19 tires - and the mustang tires are 245/45/19
The rims look nice - Just wondering if they will work.
Link is here... if it is still valid.
http://chicago.craigslist.org/nwc/pts/3851961870.html
thanks all ...
http://www.fordboltpattern.com/Ford_Mustang_Bolt_Patterns.html
To quote them:
YEAR STOCK WHEEL SIZES OFFERED MAX WHEEL SIZE BOLT PATTERN(millimeters& inches) STUD SIZE HUB / CENTER BORE OFFSET
2010-UP 17"-19" 22" 5x114.3mm 5x4.50" 1/2"x20mm 70.3mm 35-50mm
(H)
Should fit the 2007-10 Edge with a little boring out of the wheels, as Edge hub is slightly larger; watch the offset:
FORD EDGE BOLT PATTERNS
2007-2010 17"-22" 24" 5x114.3"mm 5x4.50" 1/2"x20mm 70.6mm 35-45mm(H)
http://www.originalwheels.com/ford-wheels/edge2011rims.php
Not so sure about 2011+. I think there was a post or two on this forum re: this info. You WOULD need adapters to fit the smaller bore on the Edge to fit the larger bore on the Mustang wheels, at the very least.
http://www.fordedgeforum.com/topic/8718-hub-size-difference-2009-to-2012/
Edited by WWWPerfA_ZN0W
