Horn lost its "sound"
As of yesterday I noticed that the horn on my 2011 Ford Edge Limited sounds really weak. It used to be louder but now it sounds weak or like a little boy that hasn't hit puberty :). Also, the horn sound is coming from the passenger side engine area. Is a horn also located on the driver side or is it just the passenger side?
Any ideas? Has anyone experienced this problem?
Edited by jsabia85
In order to replace I guess I have to take the bumper off?
Do you know if there are instructions on how to do this?
  1. With the vehicle in NEUTRAL, position it on a hoist. (you can probably do this in your driveway without a hoist)
  1. Remove the 5 RH front fender splash shield screws.
    • Pull the RH front fender splash shield downward to access the horn.
  1. Disconnect the electrical connector.
  1. Remove the bolt and the horn.
    • To install, tighten to 10 Nm (89 lb-in).
  1. To install, reverse the removal procedure.
