blazindave Posted June 6, 2013 Report Share Posted June 6, 2013 Just bought a used 2011 Edge SE and so far I'm really liking it. The only thing I am not thrilled about is there are some scratches on the door panels - the little silver plastic piece that I guess you grab to push/pull the door open/closed... It's the silver part below the actual door handle in this image: http://media.caranddriver.com/images/10q4/370001/2011-ford-edge-sport-door-panel-and-dashboard-photo-370186-s-1280x782.jpg (sorry, image is really large - seems easier to just click the link instead of oversizing the forum window) It's worse on the rear doors. I drove a few used Edges and I noticed that this isn't an uncommon thing. Obviously it wasn't something that kept me from buying the vehicle, but I was wondering if anyone knows if just that little piece can be replaced or if you'd need to replace the whole door panel? Or if there is a good way to sand/paint/refinish/buff/etc it so the scratches are at least a little bit less noticeable? Thanks! Quote Link to comment Share on other sites More sharing options...
richy Posted June 7, 2013 Report Share Posted June 7, 2013 I've never done it, but you can use a heat gun CAREFULLY to try to even them out. Check for vids on YT. Quote Link to comment Share on other sites More sharing options...
ferneyhough Posted June 15, 2013 Report Share Posted June 15, 2013 It can be replaced, I had my door skins off eariler in the week & poped mine off. Quote Link to comment Share on other sites More sharing options...
