Bjtoth1 Posted June 4, 2013 Report Share Posted June 4, 2013 Does the edge use the high beam or low beam bulbs as the DRL? I know they run at a lower light but not sure which lights it uses Quote Link to comment Share on other sites More sharing options...
JSR84 Posted June 10, 2013 Report Share Posted June 10, 2013 (edited) If its a 2011 - 2013 then the high and low beam are the same builb, its a mechanical flap that controles the high beams. Edited June 10, 2013 by JSR84 Quote Link to comment Share on other sites More sharing options...
sajid.ali Posted August 19, 2013 Report Share Posted August 19, 2013 Does the edge use the high beam or low beam bulbs as the DRL? I know they run at a lower light but not sure which lights it uses Front Orange Turn Signal will be used as DRL (Need to be activated through Ford IDS), once vehicle is start and in R, D, N or S mode it will becomes ON. Quote Link to comment Share on other sites More sharing options...
