Ford2008 Posted May 28, 2013 Report Share Posted May 28, 2013 I would like to drain the transmission fluid to change some seals on the transmission, but I can't find the location of the transmission fluid drain plug. I read that the plug should be located on the transmission case. Is that right. What is the size of the bolt? Are pictures available? Is there a certain procedure how to fill up the transmission fluid after I am finished with my work on the transmission or can I just fill it up till the maximum level is reached? Fill up with a running or non running engine? Thanks. Quote Link to comment Share on other sites More sharing options...
