WWWPerfA_ZN0W Posted June 16, 2019 Author Report Share Posted June 16, 2019 Looking for performance and appearance modifications for your Gen 2 Edge? The DEFINITIVE thread 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 11, 2019 Author Report Share Posted July 11, 2019 Want to wire up the shift paddles to the floor shifter on your Gen 1.5 (2011-14) Edge? Yes you can! Thanks, tmarsh and Gadgetjq! https://www.fordedgeforum.com/topic/23453-shifter-handle/?do=findComment&comment=201760 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 4, 2019 Author Report Share Posted September 4, 2019 Gen 2 Edge 2015-2018 MYs (thanks onyxbfly!) LIncoln MKX to Ford Edge Instrument Cluster Swap 2 Quote Link to comment Share on other sites More sharing options...
Newb20 Posted December 5, 2020 Report Share Posted December 5, 2020 Can anyone help with start button replacement on the 2016 edge??? How do i get to it?? Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 6, 2020 Report Share Posted December 6, 2020 7 hours ago, Newb20 said: Can anyone help with start button replacement on the 2016 edge??? How do i get to it?? Attached. I couldn't find the procedure for removing the center register, I recall that it just pulls out. Ignition Switch - Vehicles With Keyless Vehicle System.pdf 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 6, 2020 Author Report Share Posted December 6, 2020 factory manual accessible here https://drive.google.com/drive/u/2/folders/1wBzOTmEZvCvnzvmTI470QBGyYX60xDBh 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 30, 2021 Author Report Share Posted November 30, 2021 changing PTU fluid on a 2015-2018 Edge 2.0 AWD (thanks, Musclford!) 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 20, 2022 Author Report Share Posted January 20, 2022 Want to set up "Dark Mode" in your Gen 1.5 Edge without using Forscan? Here is how Scarrz did it: 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 20, 2022 Report Share Posted January 20, 2022 The op stated he used 22 ga wire. Note that SAE 22 ga wire is rated at 0.92 amps. (Can go higher, 1.5 a depending on temperature rating. If not marked on wire, assume lowest rating). Nonetheless its dangerous. The wire used must be rated at whatever the branch circuitry is rated. IE if the fuse is rated at 7 amps, all wire in the circuit must be rated to carry 7 amps. (If a short occurs, the wire will be exposed to the full rating of the branch circuit, {which is the rating of the overcurrent device}, before the fuse blows). The problem isn't if the fuse blows, but if it doesn't, as in a partial short fault and only draws 6 a. The fuse doesn't blow, but the insulation melts causing sparking and/or fire. 1 Quote Link to comment Share on other sites More sharing options...
CARR142 Posted January 20, 2022 Report Share Posted January 20, 2022 I recommend 10 amp wire on that branch. 7x 0.5= 10.5 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 17, 2022 Author Report Share Posted February 17, 2022 Frazzled trying to upgrade your Sync2 to the hallowed v3.10? jangus just might have the answer Quote Link to comment Share on other sites More sharing options...
