How To's - Powertrain, Electronics, Body, & More!
Moderator, please feel free to move to appropriate subforum as needed.
This topic is intended to provide one-stop hunting for How-To's. Posts in this thread should only contain links to other posts (on the Ford Edge forum or elsewhere) that address the Edge or the MKX. That is about the only rule I can think of. Avoiding duplicate linkages is appreciated :)
  • Like 3
A bunch of helpful videos on 2011-2013 Edge Running Lights & Puddle Lights (courtesty of Daytime BrightLites / kc300c) offsite:
https://www.youtube.com/channel/UCEW_CY18jmR76FQziasKKuA
HID Retrofit Kit Step-By-Step Installation Video:
Even more lighting related videos on Dan's YouTube channel:
http://www.youtube.com/user/kc300c/videos
Edited by WWWPerfA_ZN0W
Door latch problems: light comes on, door won't latch properly unless door slammed, etc.
Use electronic parts cleaner (thanks hunter!):
http://www.fordedgeforum.com/topic/10869-door-ajar-warning-on-at-all-times/page-2?do=findComment&comment=97238
Or use a screwdriver/pipe cleaner & brake cleaner (thanks Ungo!):
http://www.fordedgeforum.com/topic/18960-door-ajar-warning-on-at-all-times-fix
Or implement an electronic workaround (thanks ylw!):
http://www.fordedgeforum.com/topic/17687-any-work-around-for-door-ajar-issue/?do=findComment&comment=128410
  • 4 weeks later...
Upgrading your springs on a 2007-10? Here you go:
FRONT:
http://www.fordedgeforum.com/topic/12776-bolt-torque-specs-for-control-arm-and-axle/
REAR:
http://www.fordedgeforum.com/topic/12503-installing-rear-springs/
As stated in the threads, watch out for the specs with "in-lb" vs "ft-lb" measurements. 1 ft-lb = 12 in-lb.
