2011 Edge Limited w/302A
Looking to get a 1-owner used 2011 Edge with 302/A package + towing also and 20" Rims with only 20K miles. Dealer is asking 29,500...pretty firm.
What should I look for on the vehicle? Any issues that need resolving, or anything to specifically identify on the vehicle that might be a "red-flag"?
TIA!
2011 Edge Limited? AWD or FWD (since you have an Outback, I am biased to AWD)? CPO? Warranty?
If AWD, would ask about powertrain issues, specifically the PTU.
Definitely ask to see the OASIS report along with the Carfax/autocheck. This will show you the repair history of the vehicle at Ford dealerships, beyond what CF/AC will show you.
Ask what TSBs/service bulletins have been performed?
Check the cabin filter to see if its clean/new. Ours was FILTHY.
During your test drive, check for any hesitation/surging issues, under hard acceleration or while slowing down then speeding up (as if to make a turn or a yield).
How hard is it to close the doors. At this mileage you should be ok, but the door latches eventually stop working and you have to slam hard/get the part inside the door panel replaced.
Probably more regarding electronics, someone else will have to speak to that, I have a pretty basic SEL.
Thanks WWW. AWD, not CPO and AFAIK no warranty at this point.
I have checked Carfax - no issues (but lack of dealer-performed service)
It's from a local dealer (bought at auction earlier this month), but since it's a 302/A I'm guessing it's not a rental vehicle - the CARFAX indicates it was registered as a personal lease vehicle.
