Radio Static Following Aftermarket Stereo Upgrade
I recently had a Pioneer AVH-X8500BHS installed in my 2009 Edge using the PAC MS-FRD1 harness and Chrysler Antenna. Following this my AM is almost complete static and FM is a bit spotty. I'm trying to figure out what would cause this and how to correct it.
Unfortunately the install guy seems kind of bothered that I expect everything to work as it's supposed to. Any help would be greatly appreciated.
What type of antenna adapter did you use? I previously had an Alpine unit before this one and the problem was even worse. I read a post somewhere about a similar problem after upgrading because of too much/too little power being transmitted with the wiring harness. It was a bit over my head though.
I have the same issue after upgrading my '09 base model head unit with a Pioneer FH-X700BT. Used a Metra harness and a Metra Chrysler antenna adapter. FM comes in good but AM is very weak and tons of static. Do like to listen to the traffic, news and weather on the commute to work in the AM..
