Labol Posted May 12, 2013 Report Share Posted May 12, 2013 Hello, I received my new LED VLEDS is the second generation. I temporarily install the LEDs to make a test and I'm left with the problem of fast flashing. I test with both controller. I remove the 5A fuse and still the same problem. Do you have a solution for me? See Video http://www.vleds.com/v3-triton/bulb-system/v3-wa-5k.html Thank You Best Regards Sorry for english i'm french ++ Vleds QuickFlash.MOV Quote Link to comment Share on other sites More sharing options...
Weezer Posted May 12, 2013 Report Share Posted May 12, 2013 Hello, I received my new LED VLEDS is the second generation. I temporarily install the LEDs to make a test and I'm left with the problem of fast flashing. I test with both controller. I remove the 5A fuse and still the same problem. Do you have a solution for me? See Video http://www.vleds.com/v3-triton/bulb-system/v3-wa-5k.html Thank You Best Regards Sorry for english i'm french ++ Vleds QuickFlash.MOV Sorry to hear the 2nd generation of the V3 Tritons don’t work any better than the 1st generation, which I tried. The V3s are quite bright and I was hoping they’d fix the problem in the 2nd gen. Please let us know if you resolve the issue. Quote Link to comment Share on other sites More sharing options...
candurin Posted May 13, 2013 Report Share Posted May 13, 2013 Did you use 6ohm resistors? Quote Link to comment Share on other sites More sharing options...
Labol Posted May 13, 2013 Author Report Share Posted May 13, 2013 No, is build in ... Features: NEW! Smaller Control Module with built in Resistor. No Hyperflash! The load can easily be removed if desired. Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted May 14, 2013 Report Share Posted May 14, 2013 Bummer, had high hopes for those. Quote Link to comment Share on other sites More sharing options...
Labol Posted May 14, 2013 Author Report Share Posted May 14, 2013 (edited) Hi, Reply from VLEDS Support: Hi, OK we know about this issue. The new Fords have a new computer controlled lighting system and we are trying to figure out the solution. You have all the right connectors so no need to worry about base type. We are trying to get one of these cars in here to find the solution. If you can just hang in there we will get it figured out and email you as soon as we know more. Email us anytime for an update. Thank you, Customer Support Edited May 14, 2013 by Labol Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 14, 2013 Report Share Posted May 14, 2013 I wonder if they are referring to something besides Canbus? Could the problem be buried inside the SJB? Quote Link to comment Share on other sites More sharing options...
Labol Posted June 4, 2013 Author Report Share Posted June 4, 2013 (edited) Hi, today i have reply from Vleds. Hi, We have solved the issue with the Ford Edge. We have a new adapter that plugs in line with the base adapter and V3 control box. http://www.vleds.com/v3-triton/parts/10-up-ford-f150-edge-adapter.html This will solve all hyperflash and white staying on issues. This is for GEN2 system only. If you have GEN1 system please let us know and we will make a special adapter for you. Thank you, I'm order it and wait ++ Edited June 4, 2013 by Labol Quote Link to comment Share on other sites More sharing options...
wannabang Posted June 5, 2013 Report Share Posted June 5, 2013 I can't believe that they would actually make you order if their product details say that the solution is fixed and doesn't specify that some vehicles may need an adapter. Quote Link to comment Share on other sites More sharing options...
