altenator
burge1021
Is this any help, it's from the 2008 service manual
Right hand fender splash shield seems to be the key!
Removal and Installation
NOTE: The radial arm adapter is a serviceable item. Do not replace the generator if the radial arm adapter is
the only concern.
1. Disconnect the battery. For additional information, refer to Section 414-01 .
2. Remove the cooling fan. For additional information, refer to Section 303-03 .
3. Rotate the accessory drive belt tensioner counterclockwise and position the accessory drive belt aside.
4. Position the generator B+ terminal protective cover aside, remove the nut and position the generator B+
terminal aside.
 To install, tighten to 12 Nm (9 lb-ft).
5. Disconnect the generator electrical connector.
 Detach the pin-type retainer and wiring harness.
6. Remove the generator stud nut.
 To install, tighten to 47 Nm (35 lb-ft).
7. Remove the generator stud.
 To install, tighten to 8 Nm (71 lb-in).
8. Remove the RH fender splash shield. For additional information, refer to Section 501-02 .
9. Loosen the generator bolt and remove the generator.
10. To install, reverse the removal procedure.
