JSR84 Posted May 9, 2013 Report Share Posted May 9, 2013 Hey, I have a 2013 sport with the projectors and I just installed a set of HID's. But, it would seem that for some reason the driverside has a much more distinct eye in the middle of the beam. Has anyone noticed this on their edge before, or could it be an issue with the bulb? Thanks Jordie Quote Link to comment Share on other sites More sharing options...
JSR84 Posted May 9, 2013 Author Report Share Posted May 9, 2013 I went out and had another look tonight and it would appear the left headlight is actualy puting out more light than the left. Quote Link to comment Share on other sites More sharing options...
candurin Posted May 9, 2013 Report Share Posted May 9, 2013 What brand kit? DDM? 35 or 55w kit? Did you install a wire harness? Are you certain both bulbs are seated and locked correctly? What your describing can be attributed to a bulb that is a bit (off) an simply needs to be reinstalled. I course it could also be bulb anomalies/differences between the two, but I would try and rule out anything else first. The more info you can give, the better. Quote Link to comment Share on other sites More sharing options...
JSR84 Posted May 10, 2013 Author Report Share Posted May 10, 2013 I've determaned its a defective ballast. I've already made arrangments with the company to have it replaced. Quote Link to comment Share on other sites More sharing options...
SXSimmons Posted June 2, 2013 Report Share Posted June 2, 2013 I think Im having the same issue with my HID's. Ive triple checked the seating of the bulbs unplugged and replugged the connections, but the drivers side seems to be noticeably dimmer then then the passenger side. Im running 9006 Morimoto 3five (50w) 5000k with heavy duty relay. Im gonna contact TRS monday and go from there. Quote Link to comment Share on other sites More sharing options...
Dingo Posted June 2, 2013 Report Share Posted June 2, 2013 Pull up to a wall and turn on the brights. You'll quickly know if it's a bulb seating issue. Quote Link to comment Share on other sites More sharing options...
candurin Posted June 2, 2013 Report Share Posted June 2, 2013 I had to thin/shave my tabs a little on my TRS in order to full twist them into the socket. Once I did that my bulbs were fully seated and all light patters were correct and even. Quote Link to comment Share on other sites More sharing options...
