11 Edge And driver door ajar
lowesdell
Does anybody know if there is a TSB for the Driver's Door open/closed switch? About half of the time I get the alert message of door ajar and I need to open and SLAM the door closed. I thought I saw somewhere on here of people having problems. I haven't looked, but does the switch come out easily? Easily replaced? Would a good shot of contact cleaner help?
Lowesdell,
Please check out this post and make a 10 min phone call to report it. A few people have gotten it taken care of under warranty but most either shell out a few hundred dollars or deal with it by spraying lithium grease in the latch. Mine happens mostly when the temps are below 50. If it does become a recall then those that have paid to get it fixed will be reimbursed and those of us living with it can get it fixed. Good luck.
http://www.fordedgef...ge-2#entry92592
  • 4 weeks later...
In the same string as Lowesdall posted above I described a more long lasting fix than spraying in the latch mechanism alone and the potential problem. The sensor is deep inside the latch so a good way to get to it is to remove the inboard top screw and spray though that hole which goes inside the latch to the switch.
