Remote Starter Installation help needed
i just bought a 2013 edge,SEL,it have the remote start button on its FOB,i would like to install the 100 series remote starter,i am in iraq and the dealership cant do it so i have to buy the parts my self
can you please help me with the other parts numbesr for the 100 series without the need for the FOB as i would use mine.
A DIY would help me alot also.
Dear Murad,
This is the part no. BC3Z-19G364-A for remote starter kit.
You also need the hood switch (if already not equipped) : BT4Z-19G366-A
unfortunately it also comes with a set of keys, which need to be cut as per your ignition.
You can check at E-bay.com.
but after installation this setup has to be enabled / programmed by the dealer, it needs software which normally dealer have.
  • 2 months later...
Murad,
May be you already have the Remote Start System installed in your vehicle and just need to add Hood Switch + Remote Start Activation through IDS.
I have experienced the same here in Saudi with one of my friends SEL-2013.
Best of Luck
