Hitch and Wiring on 13 Sport
So I waiting to receive my Edge Sport but will be putting a hitch on it to tow a small utility trailer. I'm pretty sure im going to go with the Hidden Hitch 87617 for the hitch but for the wiring do most of you go with the T-connector harness such as the Draw-tite 118515 or do you buy the OEM Ford harness and wire it in?
Gurufarmer, Heres the part number for the OEM Harness Trailer Hitch Harness: Part# - DT4Z-15A416-A $75.00
I ended up just getting the HiddenHitch wire harness and hitch. Installation looks good and looks like it came from the factory. Only took about 2.5 hours to do the hitch and wiring install. I even soldered and heat shrinked the wire joints for the power lead and fuse holder.
