blu by u Posted September 26, 2007 Report Share Posted September 26, 2007 We're heading to the mountains this weekend (about 4 hours away) and I heard that I shouldn't use the cruise control on the hiway for the first 2000'ish Km's and that I should vary my speed. Any truth to that? Cheers, Steve Quote Link to comment Share on other sites More sharing options...
Grey Posted September 26, 2007 Report Share Posted September 26, 2007 We're heading to the mountains this weekend (about 4 hours away) and I heard that I shouldn't use the cruise control on the hiway for the first 2000'ish Km's and that I should vary my speed. Any truth to that? YES (you don't want gears and rotating parts to take an unbalanced wear pattern) Don't go WOT (wide open throttle). Don't brake hard - anticipate stops, roll the heat out of the rotor and pads if you must stop abruptly. Enjoy Quote Link to comment Share on other sites More sharing options...
akirby Posted September 26, 2007 Report Share Posted September 26, 2007 We're heading to the mountains this weekend (about 4 hours away) and I heard that I shouldn't use the cruise control on the hiway for the first 2000'ish Km's and that I should vary my speed. Any truth to that? Cheers, Steve From page 5 of your owner's manual: BREAKING-IN YOUR VEHICLEYour vehicle does not need an extensive break-in. Try not to drive continuously at the same speed for the first 1,000 miles (1,600 km) of new vehicle operation. Vary your speed frequently in order to give the moving parts a chance to break in. Drive your new vehicle at least 500 miles (800 km) before towing a trailer. Additionally, during the first 500 miles (800 km) that you tow a trailer, do not drive over 70 mph (112 km/h) and do not make starts at full throttle. This style of driving will help the engine and other parts of your vehicle break in at the heavier loads. For more detailed information about towing a trailer, refer to Trailer towing in the Tires, Wheels and Loading chapter. Do not add friction modifier compounds or special break-in oils during the first few thousand miles (kilometers) of operation, since these additives may prevent piston ring seating. See Engine oil in the Maintenance and Specifications chapter for more information on oil usage. I'll forego the usual editorial remarks. Quote Link to comment Share on other sites More sharing options...
CobraJet428 Posted September 26, 2007 Report Share Posted September 26, 2007 Thank God! Quote Link to comment Share on other sites More sharing options...
Grey Posted September 26, 2007 Report Share Posted September 26, 2007 But what if you only got the French version of the owner's manual???????? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 26, 2007 Report Share Posted September 26, 2007 But what if you only got the French version of the owner's manual???????? Alors vous avez besoin d'apprendre à lire français. Or download the English version: https://www.fleet.ford.com/maintenance/owne...als/default.asp Quote Link to comment Share on other sites More sharing options...
Gate292 Posted April 16, 2008 Report Share Posted April 16, 2008 (edited) *Note* this information was posted by my boyfriend Warm the motor up with a few moments of normal driving. Then drive it hard for about 5 to 10 minutes, including gearing down the transmission manually to generate some engine braking....ie. pull it down to 2nd gear and make the motor hold back some to. Then accelerate hard, and engine brake again. Then park it, lt it idle down for 30 to 60 seconds, and shut it off. Let it cool for an hour or more, and repeat the original step. Do this about 5 times, and then change the oil and filter. Its now broken in. Baby an engine, and it will never generate perfect ring seal. And metal parts need to be heat cycled too. Change the oil early on as well, do not leave it in the motor full of crap for long. If you need more info GOOGLE "Motoman" and read up. As a mechanic I have rebuilt, modded and broken in many engines. Drive it slow, and it will always be slow.....my 2 cents Edited April 16, 2008 by Gate292 Quote Link to comment Share on other sites More sharing options...
