H&R Springs on a Sport
Guys, I just lowered my 2012 Edge Sport with H&R springs. For some reasons, it doesnt look as low as I thought, BUT the rear is actually sitting .5" lower than the front right now. Will the front eventually settle lower more? Everything else is fine, ride, handling etc. I was just surprised the front was sitting a little higher, back looks great. Thanks.
The rears are marked 51605 R. I don't think that front and rear are interchangeable. You should be able to look at the rear springs from underneath and see the 'R'.
I took about 1500 miles or so for mine to "settle" down. In the beginning, the ride was stiff. The ride has gotten much better, or I've become used to it or maybe a little of both.
Good luck.
