kfet Posted April 17, 2013 Report Share Posted April 17, 2013 2013 ford edge limited. 15,000 miles. when i press the brake pedal, the pedal vibrates a little bit. this happens pretty much every time the pedal is pressed. it's not a shake like something is warped. it's more of a buzz/vibrate electronically made. is this normal? i haven't taken it to a dealership to get them to look at it yet. i'm pretty sure they're going to try to tell me that it's normal. i've owned many vehicles before, and i've never had this happen. Quote Link to comment Share on other sites More sharing options...
Larry Posted April 18, 2013 Report Share Posted April 18, 2013 Sounds like a anti-lock brake problem? Possible rotor? Due you or other drivers brake heavy or ride the brake pedal? If so you may have a slightly warped rotor? Don't take offense, just a thought.. Larry Northern,In Quote Link to comment Share on other sites More sharing options...
