az_edge Posted April 16, 2013 Report Share Posted April 16, 2013 *2012 Edge SEL with MyFord Touch* I have purchased an Alpine PDX-F4 Amp and an Audiocontrol LC7i. I am curious where I should install the amp. 1. I can't put it under the front power seats or the rear seats (wont fit) 2. I can't mount it on the back of the back seats because I fold them down for storage often 3. I am thinking of installing it under the rear passenger side panel (where the Sony Amp would be if I had one). However, will it get hot in there? I've searched all the forums and googled this to death. Does anyone have pics or info on where they have installed their amp? Thank you! -MM Quote Link to comment Share on other sites More sharing options...
spongers Posted April 16, 2013 Report Share Posted April 16, 2013 I put both of mine under the floor panel in the cargo area. I had to modify the plastic trays that go around the spare tire to do this, but it worked out well. There is an amp mounted to a board, then mounted to the metal floor on either side of the spare tire. Can't see a thing with the floor panel down. My sub (JL Audio stealth) is in the stock location too so it doesn't even look like I have a system installed. I do not have pics with me, but can post some later. Quote Link to comment Share on other sites More sharing options...
shoulinpanther Posted April 16, 2013 Report Share Posted April 16, 2013 (edited) I ended up buying a Rockford punch 1000 because my audiobahn a1500hct was to big to fit under the seats. I have it located under the rear seats I wanted everything hidden except the speakers of course. Edited April 17, 2013 by shoulinpanther Quote Link to comment Share on other sites More sharing options...
az_edge Posted April 16, 2013 Author Report Share Posted April 16, 2013 I guess since my amp is a class D amp I could safely install it where the Sony System puts their amp (cargo area sidewall passenger side) Quote Link to comment Share on other sites More sharing options...
Dingo Posted April 17, 2013 Report Share Posted April 17, 2013 I have an amp there, with the Sony amp. Quote Link to comment Share on other sites More sharing options...
az_edge Posted April 17, 2013 Author Report Share Posted April 17, 2013 Ok, so what about speaker wire? I bought an LC7i to go with the 4 Channel Alpine amp. How do I use the stock speaker wire? Quote Link to comment Share on other sites More sharing options...
Dingo Posted April 17, 2013 Report Share Posted April 17, 2013 We've now reached the point where you need to go to a professional installer. 1 Quote Link to comment Share on other sites More sharing options...
az_edge Posted April 17, 2013 Author Report Share Posted April 17, 2013 Ok, then should I just run new speaker wire? Quote Link to comment Share on other sites More sharing options...
Edged Up Posted April 17, 2013 Report Share Posted April 17, 2013 ahhh. I was getting all excited. how hard can it be. Ive done systems on all my other cars but this integrated radio that the edge has looks a little intimidating. Quote Link to comment Share on other sites More sharing options...
shoulinpanther Posted April 17, 2013 Report Share Posted April 17, 2013 I have done stereos for several years myself, and did the complete custom install on my honda but after buying the edge and not being up to snuff with all of the newer style cars as well as this not being my profession I didn't want to mess anything up. Take it to a professional place. It will save you stress and headaches in the future Here is my new stuff. 1 Quote Link to comment Share on other sites More sharing options...
Edged Up Posted May 27, 2013 Report Share Posted May 27, 2013 (edited) Ill take your advice. I'm just always paranoid that I'm getting screwed at any of these places. I'll do door speakers myself and put the sub where I want it then let them do the rest. Prolly put my own amps in too. Stealth mode. Let them wire everything up. Then ill be afraid they'll be like your amps don't work.....heres these for 10 thousand dollars! Edited May 27, 2013 by Edged Up Quote Link to comment Share on other sites More sharing options...
shoulinpanther Posted May 28, 2013 Report Share Posted May 28, 2013 Ill take your advice. I'm just always paranoid that I'm getting screwed at any of these places. I'll do door speakers myself and put the sub where I want it then let them do the rest. Prolly put my own amps in too. Stealth mode. Let them wire everything up. Then ill be afraid they'll be like your amps don't work.....heres these for 10 thousand dollars! You have to understand it is a customer service type of field. They provide what you ask for and as long as you are not over bearing most places will work with you. Also find a reputable place that you know someone has been too. If you cant find one just do your research and talk to a few of the places. You will always be able to tell the good ones from the bad ones because of the customer service. Quote Link to comment Share on other sites More sharing options...
wannabang Posted May 28, 2013 Report Share Posted May 28, 2013 I don't let those shops touch any of audio equipment. The couple times I have been in there, or have friends go in, the gain on my amp always gets maxed, although I haven't been charged yet. LOL Speaker wire to your speakers can be run down under the door, up the trim piece next to the door, and through the rubber grommet the holds all the wires that go to the door. You should be able to peel it back or loop a hanger and push it through. Then run it to your speaker. Quote Link to comment Share on other sites More sharing options...
Edged Up Posted May 29, 2013 Report Share Posted May 29, 2013 The only think that really intimidates me is that OEM integration stuff like a Audiocontrol LC7i or sumthin like that. Seems easy....just find the right wires...but that's the thing.....finding the right wires. I can wire an amp and install a speaker but that radio looks like a nightmare to figure it out. Wiring that into that radio me no likey. Someone do a DIY quick!!!! Quote Link to comment Share on other sites More sharing options...
wannabang Posted May 29, 2013 Report Share Posted May 29, 2013 Ahhh. I would hate to touch the 2nd gen headunit, or anything dealing with the dash for that matter. I miss the old ford headunits, where you could just pull the radio out and slide it back in. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted June 16, 2013 Report Share Posted June 16, 2013 *2012 Edge SEL with MyFord Touch* I have purchased an Alpine PDX-F4 Amp and an Audiocontrol LC7i. I am curious where I should install the amp. 1. I can't put it under the front power seats or the rear seats (wont fit) 2. I can't mount it on the back of the back seats because I fold them down for storage often 3. I am thinking of installing it under the rear passenger side panel (where the Sony Amp would be if I had one). However, will it get hot in there? I've searched all the forums and googled this to death. Does anyone have pics or info on where they have installed their amp? Thank you! -MM Considering that we are both second gen Edges, I think the best place would be where the stock Sony Amp would be. You could modify the slits in there to act as vents. Quote Link to comment Share on other sites More sharing options...
