androck238 Posted April 16, 2013 Report Share Posted April 16, 2013 I just ordered a set of Chrome Door Handles (9T4Z-7822404-AA) for my 2010 Ford Edge SEL. Installation was a breeze, however, the front and rear door on the passenger side did not have the T20 Torx handle re-inforcement screw. Instead the front passenger door had a crosstip screw, and the rear passenger door had a 1/4" hex head screw. Well needless to say, neither one would tighten down enough to fully secure the bezel. So both bezels on the right side can be pulled out if you were to pull on them. I am curious if anybody knows what the factory re-enforcement screw size/pitch/length is? I'm hoping I can just run to the hardware store to pick up a couple SS screwes to use and not have to order two from Ford (not terribly expensive, but something like 1.25 a screw). I'm just hoping whoever the knucklehead was that put those in didn't strip the threads in the door, which in that case I guess I could probably drill and tap for a larger screw. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
