chazman1117 Posted September 24, 2007 Report Share Posted September 24, 2007 I am working on adding some emergency warning lighting to my Edge and I would like to add strobe lights to the marker lights in the front headlight assembly. Does anyone here have any insight as to how to remove the entire housing from the vehicle on both sides so that I can get to the back of the unit? Thanks! Quote Link to comment Share on other sites More sharing options...
BlueLtd Posted September 24, 2007 Report Share Posted September 24, 2007 Remove the front bumper cover. Remove the 4 bolts and the headlamp assembly. Disconnect the electrical connectors. To install, reverse the removal procedure. Richard and Barbie Quote Link to comment Share on other sites More sharing options...
chazman1117 Posted September 24, 2007 Author Report Share Posted September 24, 2007 Remove the front bumper cover. Remove the 4 bolts and the headlamp assembly. Disconnect the electrical connectors. To install, reverse the removal procedure. Richard and Barbie Yikes - how bad is removing the bumper cover? Quote Link to comment Share on other sites More sharing options...
BlueLtd Posted September 24, 2007 Report Share Posted September 24, 2007 Ok are you sure you want to do this? Remove the 2 bolts from the top of the radiator grille. Remove the 4 scrivets from the top of the radiator grille. Remove the 3 lower pin-type retainers. Remove the 6 fender splash shield screws (3 each side). Remove the 4 lower screws (2 each side). Disconnect the side marker lamp electrical connectors, if equipped. Disconnect the fog lamp electrical connectors, if equipped. Remove the front bumper cover. Pull the corner of the bumper cover from the bracket. To install, reverse the removal procedure. -------------------------------------------------------------------------------- Richard and Barbie Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted October 7, 2007 Report Share Posted October 7, 2007 I am working on adding some emergency warning lighting to my Edge and I would like to add strobe lights to the marker lights in the front headlight assembly. Does anyone here have any insight as to how to remove the entire housing from the vehicle on both sides so that I can get to the back of the unit? Thanks! Maybe you should stick to putting a strobe or LED on your dash (Less headaches) Quote Link to comment Share on other sites More sharing options...
taurus2000 Posted June 5, 2009 Report Share Posted June 5, 2009 I just did this tonight to fix a busted light...not SO bad...it took about an hour to get the bumper cover off...harder to put back on than to take off...I was scared to break anything trying to snap it back into place... Quote Link to comment Share on other sites More sharing options...
Brandon Paul Posted July 31, 2009 Report Share Posted July 31, 2009 (edited) Well, removing the bumper is a no easy task. You should read some articles on how to change bumper bracket or side support. It will give you knowledge on how to remove your bumpers safely and the right way before you make any repairs on some other parts of your car. Edited August 28, 2013 by Brandon Paul Quote Link to comment Share on other sites More sharing options...
