Bob C. Posted April 7, 2013 Report Share Posted April 7, 2013 From the day I picked up my new, 2013 Sport, there has been a tapping noise from the engine bay. Fuel injector? I don't think so. Sounds more like a valve tap to me and just one cylinder. Dealer checked it out and said it was a fuel injector. I didn't buy that one, but the mechanic said everything is fine with the vehicle. Anybody have a similar issue?? Bob Quote Link to comment Share on other sites More sharing options...
Swatman27 Posted April 7, 2013 Report Share Posted April 7, 2013 I have had the same thing. It's just a quiet, but noticeable tap or click. I can hear it more when the engine is cold. I have also been told that everything is all good and it is just the injectors warming up and it will not affect anything. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 7, 2013 Report Share Posted April 7, 2013 Bob, can you post a video? On cold startup, these engines can make some unsettling noises for sure, especially when it IS cold outside. May just be a question of very brief, inadequate lubrication, tho not sure. Quote Link to comment Share on other sites More sharing options...
jmacd27 Posted April 7, 2013 Report Share Posted April 7, 2013 You could try and unplug one injector at a time and see if the noise goes away/changes. If there is no difference in noise, then you know for sure it isn't an injector. Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted April 7, 2013 Report Share Posted April 7, 2013 there is a TSB for this and its been talked about on the forum. My problem is that Im not sure I want my brand new motor opened up, something drilled out with the chance of some metal shavings going into the engine if its only to quiet a sound i only hear when outside the vehicle when its cold. My question remains, what are the problems with just leaving it be, on long term engine reliability? Quote Link to comment Share on other sites More sharing options...
