argos587 Posted April 5, 2013 Report Share Posted April 5, 2013 Need to remove the radio in '07. How do I remove the center dash bezel surrounding the radio to gain access to the radio mounting screws? Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted April 5, 2013 Report Share Posted April 5, 2013 (edited) Carefully stick a small flat blade screwdriver (like a pocket screwdriver under the bottom part of the bezel (under the a/c controls) to to help pop it out a little bit, then just pull it straight off (carefully, of course). It's just held on with little plastic snap clips.... comes off suuuuper easy. Don't even have to unplug anything from it, just lay it off to the right side and you can get right at the radio Edited April 5, 2013 by thirdgenlxi Quote Link to comment Share on other sites More sharing options...
autom8r Posted April 5, 2013 Report Share Posted April 5, 2013 Watch this http://www.coastaletech.com/edgeinstallation.htm That was easy! Quote Link to comment Share on other sites More sharing options...
