Oil leak
beauporter
I have a oil leak between the transaxle and the engine block on the driver's side of the vehicle(oil leaks where the engine and transaxle are bolted together). I'm guessing it's the main seal on the engine block. Does anyone know of any other seals between the transaxle and the engine block that could be an issue? Does anyone have any info on how difficult it would be to change the seal?
Thanks
I believe I did accidently post in the wrong section. It should be in the 3.5L forum. Anyway, I called the dealership the first time to get a estimate on the repair. and the rep. told me that they would call me back with the approximate cost for the repair. I let about 4 hours go by and never got a call back. I called them back a second time and was sent to a Ford rep's voicemail. I left a detailed message explaining the issue. I even left plenty of contact info so they could give me a call back. I haven't received a single phone call from them. Apparently they don't won't the $. I would fix it myself, but I don't have the time or engine hoist/picker to do the job. Luckily my Cousin sounds Matco Tools to local mechanics and gave me a couple of references.
  • 9 years later...
