2008 MKX - passenger lowbeam
I'm getting some intermittent function out of the lowbeam. After I get home from work it's off, but if I pop the hood and fiddle with it a bit it will come back on. I'm noticing the wire connector attached to the bulb has about 1 cm of bare wire. I wrapped it in electrical tape and I'll check again tonight.
Could it be melting insultation? If so, can that wire connector be replaced by itself? It seems to connect somewhere in the bowels of the headlight assembly.
Thanks.
